I searched for this but couldn't find the answer here so apologies if it has been discussed. I converted my bike to the 1000 watt Bafang mid drive recently. I have the big 17.4 AH 52V  whale shark battery. Everything was purchased as a complete system with less than 200 miles on the odo. I was doing my longest ride yet which was about 39 miles with some steep hills on paved roads, rough gravel roads and short downhill singletrack. My battery normally charges to about 58V and I always do a full charge. I have the recommended smart charger with the read out and my bike display also shows about the same volts. Everything went dead about 4 blocks from my house. The last voltage readout was around 42 volts and the display showed about half of the battery left. It also showed over 25 miles range left. Pressing the battery indicator button showed no lights. I have this incredibly steep hill coming up to the house and had to push the bike up it. Pedaling with that motor was a no go because it felt like I was pushing the motor also. Plugging the battery back into the charger showed the same 42 volts. I was able to get some indicator lights on the battery after a while as it got up to 50 volts. So I popped it back into the bike and everything works again. I have a few questions:
1. Is it normal for the bike to totally shut down like that? I kinda thought it would just have less power but still go.
2. What actually is causing the complete shutdown, battery, display, motor? Just wondering on this one.
3. I always pedal but I was hoping for some more range seeing as how I have the biggest battery they make. On the other hand it is frickin hilly around here. I took this one uphill (around 500' vert) that was over 10% grade and probably parts were close to 15% about 3 miles from the house. Maybe that just sucked the life force out of it. Does this range seem par for my setup?
4. Is it normal to feel the mid drive motor as a drag like that without any power? I haven't pedaled it without the power on since I installed the system so I can probably answer this tomorrow.
Thanks everybody. You guys are great.
Bobber
Bobber
