Given the dearth of bicycle parts and supply chains it’s almost a certainty. However I would surmise it to be a better bike just by the momentum of the technology. The price is another storyDoes anyone know if the specs are going to change for the 2022 Turbo Vado SL line?
Here's a guess. The Turbo VADO 5.0 SL EQ specs on the Specialized web site are for 2022 (which is not available.)Does anyone know if the specs are going to change for the 2022 Turbo Vado SL line?
Seat-post diameter in Vado SL has always been 27.2 mm.The seat post diameter is 27.2 instead of 31.8
Given the dearth of bicycle parts and supply chains it’s almost a certainty. However I would surmise it to be a better bike just by the momentum of the technology. The price is another story.
Thanks. It doesn't make sense that they would change the diameter of the seat post unless they were redesigning the entire bike. My info came from one of the dealers I found when I did a search for "find near me" - and the Seatpost spec they list is below. https://www.bikesourceonline.com/product/specialized-turbo-vado-sl-5.0-eq-step-through-391123-1.htmSeat-post diameter in Vado SL has always been 27.2 mm.
31.8 mm is the stem diameter.
Do they change the chainring to SRAM, or? Because it has been Praxis.
I agree, the drivetrain swapped for SRAM. (It's going to cost a lot on maintenance!)
Seatpost | Specialized, alloy, 2-bolt, 12.5mm offset, 30.9mm |
Sounds like they did at least for the SL - from the specialized website:Thanks. It doesn't make sense that they would change the diameter of the seat post unless they were redesigning the entire bike.
SRAM is for girls - that’s why they put it on the step through. Shimano is much better. I know that because Chuck Norris uses Shimano, and he doesn’t even own or need a bike.What’s the benefit/downside of going to SRAM?
Benefit: Prestige. Downside: High price.What’s the benefit/downside of going to SRAM?
ST from Specialized US websiteSounds like they did at least for the SL - from the specialized website:
SeatPost
It is in the Polish site (only the ST), and I was told I could get it in December at earliest.I see a Vado SL on the Spec web site showing the new TCU and other spec changes
I think it’s country specific, maybe due to parts availability. Here’s updated Turbo Vado SL 5 EQ spec for Japan:Specialized (and most other mfrs) rarely puts an actual model year on a bike, and when one "model year" ends and the next begins is totally fluid and might depend on how long it takes them to run through their inventory of parts. So until I see a Vado SL on the Spec web site showing the new TCU and other spec changes, I'm not taking anything for granted as far as what I'm likely to get next February or whenever.
I do find it strange that they would change the seatpost diameter, which involves a lot more than just changing brands of drivetrain components.
The 11-50 12 speed is showing up on some dealer sites for current inventory. I think the spec now and for next year will “be subject to change without notice” depending what Specialized has available at time of build.Now I see what you were talking about. On the U.S. site the SL 5.0 Step-Thru is a new model and is already shown with what is apparently the 2022 specs. I would expect the regular SL 5.0s to show this same spec within a couple months after any of the current models are flushed from the pipeline. The 11-50 cassette definitely interests me so I'll hold out for the 2022 model if I can. A 10-tooth sprocket is a really tight wrap for the chain and I don't really expect to do much at max speed anyway.
The 11-50t thing is even easier as it can be used without the Micro Spline driver. Not complaining too much, but the MS driver broke at my brother's Trance E+. Shimano Polska has honoured the warranty but it was hard time (even to them) to get the replacement.The 11-50 cassette definitely interests me so I'll hold out for the 2022 model if I can. A 10-tooth sprocket is a really tight wrap for the chain and I don't really expect to do much at max speed anyway.
I've had my 5.0 SL EQ for a bit over two weeks. It came with a 12 speed 11-50 and I will admit to having used the 50 a couple of times. (Conclusion - if you need/want it, its nice to have.) It is not a 2022 model. It does not have the Mastermind TCU, but does have the old TCD and TCU. JayNow I see what you were talking about. On the U.S. site the SL 5.0 Step-Thru is a new model and is already shown with what is apparently the 2022 specs. I would expect the regular SL 5.0s to show this same spec within a couple months after any of the current models are flushed from the pipeline. The 11-50 cassette definitely interests me so I'll hold out for the 2022 model if I can. A 10-tooth sprocket is a really tight wrap for the chain and I don't really expect to do much at max speed anyway.
Not 10-50t?It came with a 12 speed 11-50
Ouch. it is a not a1n 11-50 but a 10-44 or 10-45. Next time I get the wheel off I will count teeth - but definitely not a 50.Not 10-50t?
