Hi all,
Thought I'd share my new "dream build". Inspired by positive reviews coming out of Chinese frames (e.g. Dengfu, ICANN), I set out to find a CF frame designed around the M600. I wanted an "all mountain" / enduro geometry: 150mm travel front and rear. I found a brand that I hadn't seen any reviews on called "Topfire". I decided to take the plunge and order a 17" frame, sight unseen. I figured that the frame itself was not a significant percentage of the build price, so even if it was no good, I would have options.
After four agonizing months of wait, the frame was ready sent to me. I chose a custom color, which added a bit of cost and time, but it was worth it. It arrived, well packed, and undamaged in shipping. I set out to build it with a Shimano 12sp drivetrain, 34T chainring, Shimano XT wheels and 4-piston brakes. Suspension wise, it rides on Fox Factory 36" x 150mm front fork and 51mm DPX2 rear shock (150mm wheel travel). Fox dropper completes the build.
So far, I am thrilled by the outcome of this project. The M600 is a bit noisier than the BBSHD, but the PAS on it is much better and more intuitive. Much less "jerking" at low speed, compared to the BBSHD. The battery is a Bafang BT-F04, which is rated at 600 Wh. It has a nominal voltage of 43V, which is a little bit of an oddball number (12S config. I'm still trying to figure this thing out. When fully charged, I read an open voltage of around +54V, which I thought was a 13S configuration. So, I'm a little confused... Anyone else use this battery?
Anyhow, I thought I'd just share to add to the tribal knowledge. I'm just one data point, but my experience with the Topfire frame is great!
