Luto
If you use water, it is easy to find the hole in a tube. Then check that location in the tire first. Never hurts to run your fingers on the inside.Everytime you get a flat, you just have to ensure you run your fingers (carefully, of course) in the tire to ensure there is no surprise waiting for your freshly patched tube. It becomes part of the tire patch repair routine.
It also pays to keep a good, sharp eye on the road ahead while out riding. The amount of debris laying on the shoulder of our roadways is substantial, including all kinds of nails, machine screws, sheet metal screws and glass of all shapes and sizes.
Also punctures like that usually are caused by the item sticking in the tire, then you ride over it for a while and drive it in. As Mike say, stop running over stuff.
Tubeless with sealant is the way to go IMO.
