I posted this somewhere on this forum but, not sure how to move it here. I had error code 11 come on screen (fault with temperature sensor inside motor). The short version of my adventure to fix this is I was told I needed a new controller. To get the controller you buy the right side of the motor with it built in. I'm leaving a lot out but, I installed controller on motor and put on bike, turned it on and it comes up error code 11 before I even ride it! My guess is the sensor is NOT on the controller. I believe it's in the motor compartment on the stator because that's where the heat is being generated. There are two small black wires coming out of the actual motor compartment running to the controller that I think might be to the temp sensor. Can anyone confirm that's where the temp sensor would be? is it replaceable? I've taken the gear box completely apart but, haven't dug into motor side (yet), not sure if I should..... Doesn't seam to be a lot on knowledge out there on this motor but, I'm slowly learning the hard way. Thanks in advance for any help. Dave
