Merle Nelson
- USA
Ha, ha, that is an amazing accomplishment. My hat is off to you.
I do 250-300 miles a week and have taken to giving the bike a once over every Saturday, check every bolt, every nut, degrease and re-lube what I can in hopes of minimizing any damage from loose or gunked up parts.
it seems whatever I am saving from purchasing fuel for the truck by commuting on the bike is being spent on the bike.
Can’t save much over what I am paying now already looked into it. might save $20 a year if that. Plus there are too many restrictions and they don’t cover motorcycles of which I have so switching to mile based and I lose my combined discount on the motorcycle so it ends up costing more.You can save hundreds by switching to a car insurance policy that charges by the mile. Plus shaving 10k mi off your car saves several hundreds in depreciation.
Pay-Per-Mile Car Insurance: How Does it Work? | The Zebra
Pay-per-mile car insurance works by tracking the number of miles you drive in order to determine your rate. If you drive infrequently, switching to pay-per-mile might be a good move.www.thezebra.com
Lube it. Lithium grease on the moving parts. I do mine once a month.my kinekt has a creak in it now. its fine in function but a little noisy now.
did that it helped but it now has a little side to side play. not much but a little.Lube it. Lithium grease on the moving parts. I do mine once a month.
i.e. the spoke thing: a few day ago I hit a hole & tore the nipple right out of the rim.(panic.´ my motor wheelGot over 9000 miles on my bulls crossover. about 1.5 years of riding. got great life out of the Schwalbe Marathon plus about 8000 0n the front I screwed the back up so I can't know how long that would have lasted. on the 5th chain and the shifting is getting a little clunky.one shifter cable cause there was no practical way to lube it so I replaced it. headset bearings were not sealed and after months of riding in the rain they were leaking rusted grease. rear wheel rim had cracked after 9000 miles shop said it was just normal wear and tear. but it was a cheap rim. I was hearting a clicking sound I could not find out what it was. Mechanic found it the pedals are all sloppy. well about 8000 miles on them rain and shine so they need rebuilt but that's only about 20.00. second set of hand grips just replaced those cant complain about that life. I ride every day ifI am not injured and there is no ice or snow on the ground. I got 156 miles this week and I got 6000 miles in a year.
View attachment 87702View attachment 87702
Yup, but the foam in the saddle will eventually break down in a couple of years & not rebound.Do you have callouses on your buns?
That Sir, is blasphemy! You're forgivenGot over 9000 miles on my bulls crossover. about 1.5 years of riding. got great life out of the Schwalbe Marathon plus about 8000 0n the front I screwed the back up so I can't know how long that would have lasted. on the 5th chain and the shifting is getting a little clunky.one shifter cable cause there was no practical way to lube it so I replaced it. headset bearings were not sealed and after months of riding in the rain they were leaking rusted grease. rear wheel rim had cracked after 9000 miles shop said it was just normal wear and tear. but it was a cheap rim. I was hearting a clicking sound I could not find out what it was. Mechanic found it the pedals are all sloppy. well about 8000 miles on them rain and shine so they need rebuilt but that's only about 20.00. second set of hand grips just replaced those cant complain about that life. I ride every day ifI am not injured and there is no ice or snow on the ground. I got 156 miles this week and I got 6000 miles in a year.
I got 225 miles last week. I was tried after that.That Sir, is blasphemy! You're forgivenNow get back out there Soldier!
I've also been trying out some "custom" grips. I need something to help me get beyond a normally comfortable 2-3hrs without breaks. I've noticed that the different size pipe insulation is made from different density foam. The 1" stuff appears to be a bit stiffer and seems to crush over time (doesn't return to it's original size). I'm having some better results from the smoother/softer foam used in the 1/2 and 3/4" stuff. Cutting these smaller diameter pieces and adding an extra segment seems to work out well (the coverings takes care of any seems which are kept underneath the grip so my weight isn't on that area)....
Grips? Just the most comfortable ever made! After 7k mi. on ´ergo´ grips, the arthritis in my wrists was gettin unmanageable so I went back to the homemade grips i´d used on my roady. 1st I fold 9¨ of duck tape in half
to make a dbl sided tape which I coil around the bare bar. 2nd I cut a piece of 1¨ foam pipe insulation trimmed
so not interfere with brakes, & position it down on the tape. Then I tightly coil tarred nylon cord onto the foam
creating a ribbed surface. With my leather punch, I make leather coverings about 3/8´ shorter the the foam
diameter. Stitched on wet they shrink tight leaving a soft ribbed surface that shapes to hand with use. Once
dry suede side out, I waterproof them with spray urethane lacquer. Very comfortable!
Whether covered with crinkled duck tape or leather, the grips described in my post do shape to theI've also been trying out some "custom" grips. I need something to help me get beyond a normally comfortable 2-3hrs without breaks. I've noticed that the different size pipe insulation is made from different density foam. The 1" stuff appears to be a bit stiffer and seems to crush over time (doesn't return to it's original size). I'm having some better results from the smoother/softer foam used in the 1/2 and 3/4" stuff. Cutting these smaller diameter pieces and adding an extra segment seems to work out well (the coverings takes care of any seems which are kept underneath the grip so my weight isn't on that area).
My next plan is to try some padded bar tape (leftovers from my drop bar days) so I get the increased cushioning and diameter but can more precisely tailor things. The larger diameter split grip with the 1/2 twist throttle is causing me some additional headaches with this additional cushioning, so I've got a bit more experimenting to do.
Specialized make riding gloves with extra thick palm pads. They do a lot to reduce the vibration going into your hands. The pads are about 1/8” thick. I wiped out and the gloves totally absorbed the impact and not a scratch to my hands. Great product.I've also been trying out some "custom" grips. I need something to help me get beyond a normally comfortable 2-3hrs without breaks. I've noticed that the different size pipe insulation is made from different density foam. The 1" stuff appears to be a bit stiffer and seems to crush over time (doesn't return to it's original size). I'm having some better results from the smoother/softer foam used in the 1/2 and 3/4" stuff. Cutting these smaller diameter pieces and adding an extra segment seems to work out well (the coverings takes care of any seems which are kept underneath the grip so my weight isn't on that area).
