Hi, new to this board, and just happened on this thread. Hope this late comment isn't too off-topic from the original post. I'm trying to decide which Shimano SL-M6100 shift lever to get. It apparently comes in FOUR varieties, two with OGD and two without. Because I'm getting the M6100 brake lever, I can use the I-SPEC EV mount for the shifter. So that leaves two variants: with and without OGD. It seems that if you forego the OGD option, you can get 14mm of adjustment range for the shift lever. So, in addition to all of the pros/cons listed above about OGD, it seems that in this particular case, going without gives you much more flexibility as far as position of the shift levers relative to the brake lever. Does anyone have experience with this particular shifter, in particular the one with OGD? Does it fall within a comfortable position relative to the brake lever for 1 finger braking? I'm inclined to go without OGD because position of the levers relative to my fingers is more important than having the little dial window.
