@PDB415 fantastic feedback.
climbing a technical trail is certainly not my use case. I am interested in E14 primarily because I think in start-stop NYC it could be a game changer. So often I find that I have to stop abruptly at a light (Eg someone jumped in front of me) and I didn’t have the opportunity to downshift.
If I understood the limitation, here is the scenario (this I believe applies not just to Rohloff but all hub gears)
- one is going up a steep hill and doesn’t have enough momentum
- one is pressing hard on the pedal just to be able to crawl
- if in that situation if you try and downshift, you won’t be able to because there is pressure on the pedal
- so only way to let the pressure off the pedal would be to either dismount or as you described, do a “S” turn
Does that sound right?
while not an ebike, I have alifine hub drive on my non electric bike and I don’t recall this. But then my use case is very different.
