I agree it's probably thin inexpensive tubes. Since switching to Continental tubes my air pressure has been much more stable and only needs to be topped off about once a month or more.What tubes are you using? The standard tubes in my Schwalbe tires were quite thin and a 10 lb loss in a week was common for me as well. I switched to Schwalbe Downhill tubes, which are twice as thick, and the air loss is now minimal. The thicker rubber walls of the Downhill's offer a bit more flat protection as well.
handsomecycles.com
Spot on. About once a week with the ebike. I love my road bike but I hate how it needs air every time I take it out!Sounds about right. I have to pump up the skinny tires on my road bike every second day.![]()
This may be the issue. The tires were about 20psi when I got it. I've topped the tires up a couple of times now, and the loss of pressure is slowing a lot!What size tires and what's your normal pressure? Also, were they originally filled with air or with CO2? CO2 permeates through rubber and is a known problem. If you don't know what was in the tires, you might want to purge them and fill with air. (I use mostly CO2 and don't seem to have the problem, maybe because I use a lot of Slime, I don't know. But, yeah, you could easily be within normal parameters, regardless.
You could check that your valve cores are snug too.
TT
How many people with ebikes care about tubes that are lighter? If they are more flat resistant, that's s something to pay attention to, but my experience is the same as AHicks regarding Slime. Flats and pressure drops are largely eliminated with Slime. It probably adds 40% more weight to the tubes, but the electric motor on my bike way more than makes up for that.Tubolito tubes weight 40% less than standard butyl rubber tubes and are more flat resistant. I find they hold pressure for at least a month or more. They do cost more.
Many ebike riders thinking that their motors and batteries insulate them from the impacts of weight are not thinking things through. Yes the motor helps reduce the impact of weight on the rider effort. However the amount of weight of tires, rims and tubes does has real impact combined human/motor effort, bike speed, battery consumption, etc.How many people with ebikes care about tubes that are lighter? If they are more flat resistant, that's s something to pay attention to, but my experience is the same as AHicks regarding Slime. Flats and pressure drops are largely eliminated with Slime. It probably adds 40% more weight to the tubes, but the electric motor on my bike way more then makes up for that.
TT
There are absolute laws of physics, I get that. Yes, your battery, motor, tires, and everything else, will last longer and take you farther if you cut down on the weight you haul around. But there are real-world compromises we all make and accept. I ride a Rad Rover with 4" Slimed tires. If I was bound by the immutable laws of physics, (I am, of course, but I can "cheat" on them with my ebike) I guess I'd have to ride a 14 pound carbon frame racer (with no motor or battery). I don't have to, and I'm not going to. I'm quite content with the idea that my battery may only take me 41.7 miles down the road instead of the 41.76 miles I might get without the Slime. Sometimes I even pack a lunch for my ride... how much weight is that? I don't care. (Depending on where I'm biking, sometimes I even carry a 15 pound Kryptonite 5ft. Fahgettaboudit Chain! And an Abus folding lock!!!)Many ebike riders thinking that their motors and batteries insulate them from the impacts of weight are not thinking things through. Yes the motor helps reduce the impact of weight on the rider effort. However the amount of weight of tires, rims and tubes does has real impact combined human/motor effort, bike speed, battery consumption, etc.
Once you look at, think about and understand the physics of weight, its distribution and stop lugging around unneeded gear, pay attention to aerodynamics and wind drag on bags, cluttered cockpit, and yes amount of weight at near the rims, you accelerate faster, you go further on a charge can sustain higher speed...things most ebike riders care about.
How is a slimed tube for repairing with a patch?When you get tired of messing with it, try the Slime. It's cheap, it's easy, and it works.....
