I'm sure that they meant either Freewheel or cassette. My G06 On my 2020 Voltbike Yukon 750 is a Freewheel version.  Also it's the G060.500D motor.   On the screen you can see the power output.   In stock its set to output 780w ish.  I can crank it up 19A.  On a full battery it's just over 1000w out of the motor.   I will keep an eye on temperature but so far all I notice is more power, torque, and battery consumption lol.  I want to know if the 750w version is physically different at all from the 500w.   Is there any benefit to running it.?  If I were to run the 750w version at the same amperage and voltage levels as the 500w motor.  Will I see any benefit using the 750 vs the 500? Or is it just a matter of driving the motors at different power levels to achieve the rated output?   I'm worried over powering say a 500w to 1200w etc will damage it.   But I guess it's really just a matter of temperature no?
I might be able to help here a little bit. I can tell you beyond ANY doubt I am no electrical engineer. This is all my opinion, based on some messing around I have done. That in mind, if we compare a nominally rated 500w motor to a nominally rated 750w motor, all else being equal-
With both motors pulling 500 watts indicated on the display, they're pulling the same amount of power from the battery, so they will have the same battery range - again ALL else being equal.
The 750 will not use more power than a 500 while doing the same job. The 750 WILL have more power available, and will be using more power when you are using that extra available power.
If we jack the power up to 1000w indicated, the 500 will overheat before the 750 does. Neither motor will be damaged unless it's overheated. A short shot of 1000w is not going to hurt either motor.
The 750 will likely use a little less power than a 500 in city traffic and on trails as it has more "grunt" than the 500. It is able to just power over a slight incline that might require you to use additional throttle on the 500.
The 750 will smoke a 500 in a drag race....
All this in mind, my choice would always be the largest motor available - knowing full well it's not going to use any more power than a smaller one while doing the same job, AND, it's going to have extended capabilities. Currently riding a RAD City with a conservatively rated 1000w MAC 12t geared hub, that's giving me a range of 35 miles easily on a stock RAD battery. I see NO downside to having this amount of power available - and it will easily climb any paved hill I point it at with my 300 lb butt on it . -Al
