IOUZIP
- USA
I have been working on this brake upgrade for some time. The stock 180mm dual piston brakes are good but I was ready for some better braking power. I was trying to get a set of the Tektro HD-E725 brakes but they have been out of stock for a few months. So I decided to get a the HD-M725 brake kit. I was not going to use the brake levers. I did used the hose and brake calipers. I kept the Star Union brake levers which have the motor cut out switch. Now I am still in the process of rebuilding the bike after some hard trail activity over the last year. 203mm front and rear rotors with Tektro 4 piston calipers. Started with front will add more pictures as it progresses.
Stock 2 piston Star Union calipers next to the Tektro 4 piston Orion 4P calipers.
Tektro brake line fitting screwed right into the Star Union lever.
When you bleed this brake system it was tricky. First used a syringe with Tektro mineral oil brake fluid and the right hose fitting in the caliper. Crack open the cover to the reservoir push the brake fluid up throught the caliper. Catch the overflow with a rag. Raise the caliper level to the lever height and remove the syringe from the caliper. Reinstall the screw in the caliper. You will need to burp the brake lever with little pulls on the lever. Once the air bubbles are gone reinstall the cover.
