Handlebars
- Canada
branching from this thread: https://electricbikereview.com/foru...a-mask-when-you-ride.36605/page-3#post-378731
I have only heard about this as a headline so I don't want to comment too much but my first impression was that was a mistake on the testing side and not the actual vaccine. None the less I am a pro vaccination and that gave me some pause when I heard that."The medical field requires very stringent guidelines regarding testing and approval of drugs for anything obviously including deadly viruses. "
Do you believe that the Australian vaccine which caused people to test HIV positive was
thoroughly trial tested in that manner?
Agreed. However, I do not believe that creating a blog site of my own would be more effective than using such sites.@Handlebars
"point noted regarding complaining about censorship on social media. Defining the platform is up for debate. I would consider the platform to be the internet, not the company. With a little extra effort you can create your own blog site and post whatever you want.
That it has those problems with heart was very well known before any of this.Forgive me if I'm jumping around, hydroxychloroquine has shown serious problems with heart rhythm while showing no benefits in the studies performed by the NIH. FDA removed its authorization for emergency use after those studies concluded.
It is interesting that it's being said to produce false positives, but they are not false positives as in how some covid tests are said to produce false positives.I have only heard about this as a headline so I don't want to comment too much but my first impression was that was a mistake on the testing side and not the actual vaccine. None the less I am a pro vaccination and that gave me some pause when I heard that.
Edit.
Ok since you brought it up and I had admittedly forgotten about that headline I looked in to it a little more and found this
"The vaccine contained small fragments of an HIV protein, which helped stabilize the vaccine. Some of the participants developed antibodies against these fragments, and these antibodies triggered false positive results on some HIV tests.
It's important to note that there is no way for the vaccine to cause an HIV infection, because it contains harmless fragments of the virus."
That was copied from livescience.com. Forgive me it's late and I'm doing all this from my cell phone while my wife asks why the hell I'm still up. That's a pretty wild situation that is on some levels a little scary but also pretty fascinating.
It is worth noting that the participants were informed that these fragments were being used in the vaccine however it was thought that due to the very miniscule amounts it wouldn't show up on an HIV test, they were wrong and rightfully pulled the plug. Still I will admit the idea that someone figured out that trace fragments of HIV could be used to stabilize the vaccine is very interesting. If only chocolate worked better.
The Australian department of health is categorizing the HIV tests as false positives because the participants don't actually have HIV, their bodies developed antibodies for HIV due to the fragments.It is interesting that it's being said to produce false positives, but they are not false positives as in how some covid tests are said to produce false positives.
They are testing HIV Positive, which does not mean infection, it is only a positive to that test. There is no error in the test from setting over-sensitivity. Also as you'd know, there is no "False Positive" result from the test.
That is just to take note of the spin being put out about it.
That HIV parts combine with SARS virus is actually several years old research in Gain Of Function, where scientists from USA and China combined the two in order to achieve a virus with new functionality in order to produce something that would be a huge threat to humanity for the proposed purpose of being able to then study to be able counteract the huge threat. That was circa 2015 I believe.
The warnings to watch for heart problems from HCQ in susceptible individuals was well published LONG before covid.@Handlebars
Yes the heart rhythm effects of HCQ (btw that is so much better than typing out the whole name) were known before Covid. What wasn't known in the beginning of covid was the effects it had on the heart. Initially it was thought to be just respiratory. It wasn't until later we learned of its affects on the heart which would make heart complications from HCQ more exasperated.
Yes I agreed to that when you already stated such. I'm sorry I'm confused as to why you are reiterating this point. I think maybe it was the way I worded my response. The effects covid had on the heart were not known in the beginning of the pandemic. It was originally classified as a respiratory virus.The warnings to watch for heart problems from HCQ in susceptible individuals was well published LONG before covid.
"Having determined an appropriate sample to recruit, it is necessary to estimate the size of the sample required to allow the study to detect a clinically important difference between the groups being compared. This is performed by means of a sample size calculation.5 As clinicians, we must be able to specify what we would consider to be a clinically significant difference in outcome. Given this information, or an estimate of the effect size based on previous experience (from the literature or from a pilot study), and the design of the study, a statistical adviser will be able to perform an appropriate sample size calculation. This will determine the required sample size to detect the pre-determined clinically significant difference to a certain degree of power. "I am not in the medical field so I have no idea and would not care to venture a guess as to what constitutes a large enough study to be considered appropriate. I can only trust that well established organizations like CDC, NIH, and FDA have their requirements and they know what they are doing.
I will, and thanks.I don't mean to cut this short but it is almost 1:30am here and as I had stated earlier I have a 2 year old in the other room which means I'm getting at best 5 hours of sleep, 4 hours at worst. You are a spirited debater and I certainly gained some insight from your posts.
do check out that documentary on Netflix if you can. Very eye opening.
Sorry, yes indeed, I was reading that too hurriedly and mistook the meaning.Yes I agreed to that when you already stated such. I'm sorry I'm confused as to why you are reiterating this point. I think maybe it was the way I worded my response. The effects covid had on the heart were not known in the beginning of the pandemic. It was originally classified as a respiratory virus.
I agree that Trump applied pressure - there also was huge political pressure to dispose of it because of high visibility of the Trump support for it.Oh and one last thing about HCQ. The political pressure to authorize it for emergency use came from Trump who continued to pressure the FDA about it after they deemed it ineffective and potentially unsafe.
