SLONomad
I have been tweaking/riding/tweaking the AM100 for several weeks now and was always mystified by its underwhelming performance on hills and its inability to attain the advertised 28 mph speed. Today I realized what might be the reason. Riding with the screen set to display the amp hours being delivered to the motor, I noticed that regardless of the Power Level setting, the maximum PAS boost was 6.0 Ah. On the other hand, using throttle alone, the battery delivered up to 15 Ah. Unfortunately, the throttle does not operate when pedaling, otherwise, you could get the best of both worlds... maximum boost on top of pedal power. So, my question to the forum: is anyone aware of a personalization setting that can increase the Ah limit while pedaling? I'll also ask tech support.
As to the reduced maximum speed, it is simply a matter of the power boost going from the maximum (6.0 Ah) to zero when the speed reaches 24 to 25 mph. It would seem logical that this should be able to be reprogrammed in the Speed Limit setting, which allows a max setting of 50 km/h (31 mph), but the controller manual says the upper limit is 40 km/h (24.8 mph), so I guess that is as good as it gets.
Note that the AM100 controller is the YL80C, the same as used on many of the other eAhora models.
