RolandSchitt
The CCX has 2.2x the battery capacity (it's basically the same as having the Vado 3.0 battery PLUS the 600wh battery), so even with a difference in efficiency it's hard for it not to win out by a pretty wide margin. Well, if you're going at similar speeds anyway. If you're using the CCX motor to go 20-25mph then that's a different story haha.I'm not sure about the higher range of Juiced CCX. Yes, Juiced has a larger battery but it also has the energy-hungry 750 W motor, rear-hub in addition.
