Consider the two racks in this picture.
The one on the right came with my Bolton Foxbat. Weight limit: 25kg/55lbs.
The one on the left is an Axiom Fatliner. Weight limit: 110lbs. Also, it doesn't actually fit on my bike and the hardware for the rear axle shims sheared while taking them off. So it's going back.
Just looking at these, I would think the one on the right is the chonky thing that'll hold anything. I just realized that I've picked the rear end of the bike up from the rack just fine and probably instantly violated the weight limit in the reverse direction. No problems. Is there a major variation in the metals used? Is the Axiom made from forged fairy moonbeam ingots while these default ones are made from compressed Chinese melamine?
Going into other bikes: I tried an Evelo Aurora Limited. Its rear rack is integrated into the frame. You couldn't replace it if you wanted to. Weight limit? 45 pounds. While looking at other bikes, I was looking at the Dost ones with the integrated rack. Those have a 100 pound limit, which seems more reasonable to me.
Some other things I considered:
1. I figured the actual weak points are the bolts. The fittings look identical. I don't think the Axiom is using, say, grade 9 fittings--or really any other kind of fitting different than the one of the right. I wouldn't be surprised if they came off the same assembly line.
2. The shims. The Axiom shim is something like half as thick as the ones on the right. It doesn't look that way in the picture.
So what's up with this? I have some gigantic Ortlieb panniers coming in soon and I'm hoping to just mount them on the ones on the right and load them suckers up at the supermarket. It won't be 110 pounds but with a few 12 packs of cans and some milk, I've exceeded 75 pounds of stuff before.
