Akrotiri
 - Europe
I found out from Court’s review of the allant 7 about the derailleur “ clutch” or whatever it’s called that is on the derailleur system of the allant line.
I know what it does basically that when turned up it tightens the derailleur cog and chain so it doesn’t move about violently and when switched down it allows the derailleur and chain substantial freedom of movement laterally
My question is when exactly should I have it switched up? Should it be for smooth roads? And should I switch it down for when riding on bumpy terrain such as bad roads, dirt trails, gravel roads etc.
My other question is for 10th gear. When exactly should I use it ? I tried it out in the open road at very high speed but I felt vibrating in the pedals. Only when I downshifted to 9th or 8th the vibrating pedal feeling went away. Is it because I rarely use it that it’s not broken in on the cassette? Or is 10th gear only for downhill? Bad Pedal bearings perhaps? All just guessing on my part but if I don’t use a lot of torque in my cadence while I’m 10th the vibrating is minimal. Any help on these two questions greatly appreciated.
I’ll attach a photo of derailleur “ clutch” circled in yellow so everyone sees what I’m talking about.
