AxialFlux
After the success of the Townie conversion, I figured I would convert my mountain bike, a Schwinn Taff. I ordered a CSC 1000 watt 29" rear wheel conversion kit, and the install went well with a couple of exceptions.
First off, this kit has the 3 ring terminals for the motor wires, and a big plastic block that you bolt the rings to. Not a big deal, except that huge block would not fit in my enclosure. So I decided to snip the rings, and use Anderson connectors there, so as to get rid of the connecting block. Hopefully, that is fine.
Second, the kit came with the normal PAS sensor ring that requires you to remove the crank to install it. The kit I got for the Townie came with this as well, but I ordered the split ring type, so I don't need to pull the crank. It works well on the Townie, so I ordered another one for this kit, but I am getting no pedal assist. The LED blinks as you pedal, but the motor never kicks in. I went through the settings, although I am really not sure what I am looking for. This kit uses the LCD3 display, and all the settings seem to be different than what my other display used.
Lastly, when I was first testing this out in PAS level 1 using throttle only, it would work fine on first use. What I mean, is I would give it throttle, go up to about 15mph up the slight incline in front of my house, and then coast back around to do it again. On the second attempt, the motor would stutter, and almost try to lock up it seemed. I checked all of my motor wires, included the big connector which I assume is the hall sensor connector, and everything seemed fine. Lifted the back wheel off the ground, and it ran fine, so I tried another test. Again, got one good run, and stuttering. I finally checked all my plugs, including the throttle connector, which I unplugged, and plugged back in. Now it seems to be working great. I just spent about 15 minutes going up and down my street with no issues. Would a loose throttle connector do this?
