Brake upgrade
chipgibbs
New 203mm front rotor. Cheap upgrade to stop an 80lb bike & 260lb rider.
Hi Chip, did you have to modify caliper mounts or is this a remove and replace upgrade?
Thanks for the info.
If you have a Cheetah and are running the stock Tektro metallic pads, don't be afraid to try some aftermarket semi-metallic pads.
I just installed a set of "Jagwire" pads and they are significantly quieter and stop with alot more authority. I got them from Amain cycle for about
$30. Cheap & obvious upgrade. We'll see how long they last.
