Accelator lever
Hud
Intermittent problem when I depress acceleration lever. Get heavy drag like brakes r on
Hud;
I had a similar problem on my 2019 CCX; the 'attached' PDF file presents the salient portion of my trouble ticket entry. Does "Walk Mode" work OK? If so you, probably, have a faulty Thumb Throttle (switch). Easy to replace, although I did learn (the Hard Way) not to slacken of the grip retaining tension screw too far - the little devils inside refused to cooperate for quite a while putting the grip back on...…..
Good Luck
  • Juiced Bikes Trouble Ticket Extract.pdf
HAd the same problem today. Bike is new and has 25 miles on it. Pedaling worked fine. 10 miles in it finally started to work though not an instant response. I had to hold down the throttle for about 3 seconds before it kicked in. I did adjust the brake levers slightly by moving the hand lever in a bit closer to the grip. Wondering if this was the problem.
