smorgasbord
- USA
The problem is the Synapse has the WTB Byway TCS, 650b x 47mm tire that seems to be glued to the rim.
If you remove all the air from the tube (removing the valve stem is the easy way to do that), then you should be able to squeeze the tire's sidewalls towards each other and wiggle the tire free. Do you know if the tire is mounted tubeless or not?
