Just another tip; IF you have a flat in the middle of nowhere it's a long walk home if you not prepared to deal with it. I removed
the stock kickstand & replaced it with a dbl leg '&' a rear mount single stand. The dbl comes with an upper clamp you won't need.
Just run the the bolt thru the frame into the lower portion of the dbl. It will lock securely into the frame. (much simpler with wheel off)
Why am I doing this? To make tire repair in the field less of a nightmare! The dbl stand let's you drop out & replace the wheel without
turning the bike upside down & crushing your display, mirror, or whatever while making the process ' somewhat' easier.... but there's
a trick to it! A) Manually slack chain off the chainring. B) After disconnecting the power cable, ( at this point I tape a sharpie cap
over the end to protect the connector prongs), C) Remove all washers & nuts from the axle,(you can leave the right side hanging
on the power cable) If you simply loosen them, the nut will snag on the derailleur when you drop out the wheel. When tightened the
axle twists & locks into the drop out. To drop the wheel, carefully use a crescent on the flat sides to align the axle to drop out, avoiding
damage to the threads. (!) D) Slip chain off freewheel & slide out wheel.
Replacement: A) lift the stays, ( the frame will now rock forward on the dbl leg.) roll in wheel, loop chain onto freewheel, & lower
dropouts onto the axle being careful to align the flat sides of the axle with the dropout slots,( this is just easier without nuts & washers)
B) The washers with the tab insert with the tab "under the axle from the outside" first!, then lock washer, nut. Reconnect power cable
being 'very' care to align the arrows!!
IF this sounds complicated, try doing it with the bike upside down in the field.
There's just no simple way to deal with a rear motor
wheel, & it's easy to screw up if you don't get it 'exactly' right! This is the main plus for a mid-drive. The plus for a rear motor
is that it will get you home on throttle if you are injured or have broken a pedal or chain. Being able to rock the bike on a dbl leg
kickstand also makes doing the front easier too, as well as tuning, since your can turn the pedals without hitting the kickstand with
the wheel off the ground. (Things not mentioned in the manual )
