Specialized Turbo Vado/Como/Tero/Tero X User Club
@Kam1936 and @Nxkharra please engage the grey clutch (move from the red to the blue position) if you want to have better rides. The Shadow clutch prevents the chain against bouncing. Disengage for the wheel replacement.
@Stefan Mikes thanks. I just checked mine. The blue position (shown in your picture) in my case is the disengaged position. It is to be used for taking the wheel off only as it releases the derailleur for more giving. At the blue position the chain rattles and hits the chain stay tube.
I was always instructed to keep it engaged which is the red position in your picture.
Please let’s clarify.
is yours different or am I confused?
May 4, 2020 1:16:44 PM - test
- Movement time: 47:05
- Total miles: 11.83 mi (▲ 2.0 mi | ▼ 0.9 mi | = 8.9 mi)
- Average speed: 15.1 mph
- Total ascent: +511 ft
- Battery consumed: 29% (171Wh)
- Average consumption per MI: 16.83 Wh/mi
- Percentage of average assistance: 52.7%
- Wh ride: 215.3Wh
- Biker: 20.6% (44.3Wh)
- Battery: 79.4% (171Wh)
FULL STATISTICS:
Bike parameters:
Advanced user - 20/40/80 PP 40/80/100 ACC 2% Shuttle 0%
- ECO: 20.0%
- TRAIL: 40.0%
- TURBO: 80.0%
Manual assistance changes: 2
- TRAIL: 1
- TURBO: 1
Date time:
- Start: May 4, 2020 1:16:44 PM
- End: May 4, 2020 2:07:47 PM
- Total time: 0:51:02
- ECO: 22:33 (47.9%)
- TRAIL: 00:01 (0.0%)
- TURBO: 24:31 (52.1%)
Movement time: ▲ 0:09:00 | ▼ 0:03:34 | = 0:34:31
- ECO: ▲ 0:02:30 | ▼ 0:02:36 | = 0:17:27
- TURBO: ▲ 0:06:30 | ▼ 0:00:58 | = 0:17:03
- ECO: 4.73 mi (40.0%)
- TRAIL: 0.00 mi (0.0%)
- TURBO: 7.09 mi (60.0%)
Total miles: ▲ 2.0 mi | ▼ 0.9 mi | = 8.9 mi
- ECO: ▲ 0.4 mi | ▼ 0.6 mi | = 3.7 mi
- TRAIL: ▲ 0.0 mi | ▼ 0.0 mi | = 0.0 mi
- TURBO: ▲ 1.5 mi | ▼ 0.3 mi | = 5.2 mi
Total miles with assistance: 10.16/11.83 mi (85%)
- ECO: 3.78/4.73 mi (79%)
- TRAIL: 0.00/0.00 mi (100%)
- TURBO: 6.37/7.09 mi (89%)
Battery:
- Start: 99% (585Wh)
- End: 70% (414Wh)
- Consumed: 29% (171Wh)
- ECO: 5.2% (30Wh)
- TRAIL: 0.0% (0Wh)
- TURBO: 23.8% (140Wh)
- ECO: 8.08 Wh/mi
- TRAIL: 4.46 Wh/mi
- TURBO: 22.04 Wh/mi
Range: 24 mi (▲ 1238 ft)
- ECO: 51 mi
- TURBO: 18 mi (▲ 1221 ft)
Battery temperature:
- Min: 80°F
- Max: 98°F
- ∅ : 88°F
Motor temperature:
- Min: 96°F
- Max: 150°F
- ∅ : 123°F
- ECO: 12.6 mph
- TURBO: 17.4 mph
Average speed: ▲ 13.2 mph | ▼ 15.7 mph | = 15.5 mph
- ECO: ▲ 10.3 mph | ▼ 14.3 mph | = 12.7 mph
- TURBO: ▲ 14.3 mph | ▼ 19.6 mph | = 18.4 mph
Maximum speed: 26.7 mph
- ECO: 20.0 mph (13:26:04 - mi 1.68)
- TURBO: 26.7 mph (13:44:13 - mi 5.28)
Average cadence: 61 rpm
- ECO: 53 rpm
- TURBO: 67 rpm
Maximum cadence: 100 rpm
- ECO: 78 rpm (13:25:16 - mi 1.51)
- TURBO: 100 rpm (14:02:48 - mi 10.80)
Kcal consumed: 173 Kcal
- ECO: 62 Kcal
- TURBO: 111 Kcal
Average Biker Power: 65 Watt
- ECO: 51 Watt
- TURBO: 77 Watt
Maximum biker power: 237 Watt
- ECO: 210 Watt (13:19:20 - mi 0.17)
- TURBO: 237 Watt (14:02:40 - mi 10.77)
Average Motor Power: 255 Watt
- ECO: 98 Watt
- TURBO: 385 Watt
Maximum motor power: 772 Watt
- ECO: 315 Watt (13:19:20 - mi 0.17)
- TURBO: 772 Watt (14:02:38 - mi 10.76)
Total Wh biker: 44.3 Wh
- ECO: 15.7 Wh (35.6%)
- TURBO: 28.5 Wh (64.4%)
Total Wh motor: 167.0 Wh
- ECO: 29.8 Wh (17.9%)
- TURBO: 137.1 Wh (82.1%)
Maximum altitude: 1266 ft
Minimum altitude: 944 ft
- ECO: +97 ft (19.0%)
- TURBO: +414 ft (81.0%)
Total descent: -326 ft
- ECO: -193 ft (59.3%)
- TURBO: -132 ft (40.7%)
Uphill altitude gain per hour: 3411.4 ft/h
- TURBO: 3825.8 ft/h
Downhill altitude gain per hour: 5498.1 ft/h
- ECO: 4475.8 ft/h
- TURBO: 8247.8 ft/h
Maximum slope: 8.8%
- ECO: 5.1% (13:26:35 - mi 1.81)
- TURBO: 8.8% (14:06:31 - mi 11.81)
Minimum slope: -6.0%
- ECO: -6.0% (13:20:35 - mi 0.44)
- TURBO: -4.6% (13:51:47 - mi 7.63)
A lighter note: I'm loving BLEvo!! The stats average mph and distance is on point. My ride back from lbs. I read some negative things about BLEvo and I have to say this app is killing Mission Control. No comparison. I even purchased the handle bar phone holder and man, I love it! There are visual and verbal stats to occupy you on your ride. You can also get them in less then 5 minute intervals. I played around with the settings. Wow! Sometimes it's hard to tell if I'm ascending or descending but BLEvo clears it right up. Tells me spot on my exact elevation as I'm riding. BLEvo is the real deal! Caution. If you have Android 10 I don't recommend. Seems it is not ready for the new OS yet. Android 9 is flawless. The time of my ride was 30 seconds off. I keep forgetting to pause the ride while I'm moving with my phone. Other than that. I think it's very accurate. I set my wheel size according to MC 88.7 is close as I can get. Imperial not metric. Compare if you will. 😎
I have no idea. I ruined them due to ignorance. However, after replacing all was well until the cleaning. I think the person who cleaned the front was careless or in a hurry or both. How do you test ride the bike and not hear that loud sound. He was test riding but only applying the back brake until I caught it. He was quick to apologize after the jig was up and anxious to fix. I think he was hoping I wouldn't notice. His remedy helped but no where near like they were before cleaning. Silent. Strange thing the back brake is fine. Silent.
You could check your original rear rotor for the model. If it's an RT56, then the tech replaced like with like. If not, there's another discussion topic with your LBS.
Thank you sir. I'm over it. I've moved on to greener pastures. There was so much good about today that I'm focusing on now. BLEvo!! Killer app. Phone mount to handlebar, perfect. Stats, on point!. Max speed, average speed, distance, visual and verbal real time, I'm impressed!. I'll see what's up with my lbs tomorrow. All good.
I stumbled on another cool feature in BLEvo audio stats. Projected range adjust to input elevation and level of assistance. You get real time audio info of your projected range as you ride.
No worries. We are all clear now.
Not certain but to my experience when clutch is disengaged gear Chang is smoother.
but chain rattles if the road is bumpy. So to be sure I always ride with clutch engaged.
My experience too. Changing gears is smoother when the clutch is disengaged, i.e. in the front position (blue arrow in @Stefan Mikes picture). I leave it in that position most of the time. Riding on rough/bumpy terrain it's best to engage/close the clutch. But not all the time.
He put these on. Worked perfect. Not a sound. After lbs cleaning almost 2 months later a loud howling noise.
Its time to get hold of that customer
and beat him so he won't do it again. :D
The resin pads they installed should be fine. It sounds like they were until after a cleaning. The rotor they installed, the RT56, is rated for resin pads only, but should be OK with the pads they installed. I would note that my Vado was equipped with more expensive RT76 rotors which are rated for resin or metallic pads. What rotors did your bike have as original equipment?
I agree with that. My BR-MT500 brake has the RT56 rotor and it's good value for money in that combination. Installing a RT66 rotor instead would have left the choice between resin or (sinter-)metal pads which you do not have as RT56 is resinpad use only.
But I doubt that Specialized has put this RT56 (or RT66) rotor OEM on any Vado 5.0 class3 bike combined with BR-M8000 caliper, and nor would I. It's OK but it could be better.
Rotor cleaning should be done with alcohol only as @Sierratim advised.
Never to use automotive brake cleaner!
@TS25 "Its time to get hold of that customer..." 🤣😂. Seriously, I know nothing. That's why I depend on @Stefan Mikes and @TS25 to put me up on these things? Where's the do and don't videos or tutorials for dummies like me. Man you guys let me down on that one. 🤔 I fault my Turbo Vado mentors for not putting me up on this stuff.😁 Still, I learned my costly lesson only to have a professional dummy repeat a similar performance. 😂 Seriously?!
👌. I'm sure he didn't use automotive cleaner in a bike shop. To a great extent I'm at the mercy of my lbs. I rely on their professionalism to fix things properly when I have my Vado serviced. There's some bad blood between myself and the local shop for sure because I went over their head to get my display upgraded from the BLOK. Also, I had to wrestle with them to put the original wheels back on there that they swapped from the Turbo Vado 3. I was riding around with 10 cogs for about 600 miles until I realized there was supposed to be 11 on my Vado 🤔 They corrected it but, shouldn't they know this from the beginning? The owner made them fix everything. I went from 28 spokes front and rear to 32 spokes front and rear DT Swiss. At least that's what I believe them to be. For certain there's 32 spokes now on each wheel. Wheels, Cogs and new display were fixed at no cost to me. I don't know anything about bikes but I know how to read and count. The lbs also initially charged me $5000 for my bike claiming it was a 2020 Vado. I caught that too. They ended up refunding me $750 plus 9.5% sales tax. They offered me a new 2020 Vado but I opted for the 2019 Vado that I had already at $4250. It's been a roller coaster ride with my lbs. I'd like to think that so far I'm winning. Who knows? I only know what they tell me until I find out differently.
No way.
We'd miss your stories to blather about. 😁
I'm an autodidact in bike repair too, and I start with reading documentation and (dealer) manuals. You can find a lot of them on the Shimano homepage including how-to's with pictures. It helps to understand how components work as discussing open points helps too. Only after acquiring knowledge I'd put my hands on. And then it's easy learning by doing which includes doing things wrong from time to time (but seldomly).
Learning lessons is costly be it money or time to acquire knowledge for DIY. I stick to the belief: if you want it done properly, DIY.
Now tutorials are a different level. I can't see any responsible amateur bike mechanic do them for real brake maintenance, and nor would a professional do it. You'd be blamed for every mistake that beaten customer makes be it following strictly or not.
I understand your feelings Kam. As I said, I never touch the brakes for maintenance myself as I am able to screw up a simplest thing and the brakes are vital for my safety.
The drive-train is the other department of this kind although I know how to repair a broken chain.
Besides, my Vado has sat at the LBS for two working days now and no signal it has been upgraded. Can bet the guys there cannot figure out how to replace the display.
You could guide them to this Video
which would be a fine tutorial for @Kam1936's next rainy afternoon exercise too.
Might need another afternoon to fix it together again. :)
@Stefan Mikes may be you should send him the how to video that someone posted here about the changing display just to make sure he is doing it right. That was made for LBS and am sure he has also access to it.
I recall it was very involved although doesn’t seem a display change being that difficult to change.
Yes it was @TS25 who posted this great video.
