Adding a water bottle to Quick E+
myershse
I wanted to attach my Tigr bike lock to the frame and needed another set of bottle cage mounts. I installed 5mm rivnuts to the the underside of the top tube. I could also use this mount for a water bottle. However, I think it would be preferable to mount a water bottle on top of the tube. If you decide to install rivnuts, I would recommend using ones made from aluminum. Installing stainless steel rivnuts would probably require an installation tool.
Like.
Just ordered one of those camelbak bottles. Like it??
The redesigned camelback is an improvement over the old design. The spout has been redesigned to make it easier to clean. However, the bottle is not quite as flexible. -- I would buy it again.
Got mine - seems to work pretty well.
I thought it was insulated. Oh well.
It’s an expensive $3 plastic bottle. 🤣
