IF you want to "piggy back" a battery on the new style 'in tube' battery to achieve the higher capacity, but out the gate, it is what it is andTHAT is what should be used to compare apples to apples; forget the accessories, the extras. What you get for the stock base cost is what should be used for comparisons to competitive products. After all, we all know that additional accessories add cost, so when I see all these numbers, lets compare what is to what it is.......
For the base model 8s, we can say that it is a better bicycle than the super commuter since it comes with the new bosch motor and 625wh battery which has %25 higher capacity. It is also $1K cheaper than the outgoing model. Even though base model comes with 625wh battery, having the option of dual battery is still a big plus over super commuter.
Instead of 9s though it would have made much more sense if they had 8s with rohloff and possible suspension fork.
