Cyklefanatic
Enough everyone about regulations, licensing and top speed. Please limit comments to hardware and design.
Thanks everyone for the comments. It looks like three types of ebikes are in order for 2025.
Type one, low cost for casual occasional riders.
Type two, light weight simpler ebikes for easy car loading and general simplicity.
Lastly an all out technology showcase with a high top speed and some type of licensing.
My original post below,
Let’s imagine what the future holds for a street/ commuter ebike.
By 2025 I see ebikes becoming more like small quiet practical motorbikes.
120 mile range 6 pound batteries, 10 year life at 90% capacity.
Derailleurs disappear and gearbox’s are built into the mid motor. More reliable and much less maintenance. 5 speeds 500% range that uses the motor power after shifts to maintain a desired cadence. Auto shifting with manual override.
All bikes have regen and rear brakes disappear. Applying the rear brake lever turns up the regen. This also makes flat repair easier and reduces unsprung weight.
The dashboard is all in your cellphone that’s mounted on the bars, the bike charges the phone. The phone connects to a rear view camera instead of using mirrors.
EBikes get heavier because they can. They include lights, brake lights, A built in trunk bag/panniers, steering locks or cafe locks, good fenders, electric locks controlled by your phone. The battery key controls all the security locks.
Due to higher speeds full suspension , 3 inches in front, 2 in the rear. 26” front wheel, 24” rear wheels, 2.25” wide. Longer wheelbase mostly added between the pedals and rear axle for stability. Ride improves due to suspension and that offsets the smaller wheels.
Single arm rear swing arm. The rear Wheel unbolts like a car 3 or 4 bolts attached to a hub. Chains are gone either Shaft drive or gates belt. The shaft drive stays in place when the wheel is removed.
Regulations are changed to allow a pedelec 30 mph top speed. Riders are licensed but the bikes are not. Licensing is mainly common sense safety training. Rather than a hard speed limit the motor will decrease assist slowly the faster you go. This would make it feel more natural.
What did I miss?
What did I miss?
