Hi I have an older stromer sport model.just recently when I turn it on the display (not lcd display) after about a minute not even doing anything it goes to overheat light on.
I transferred the battery after my older V1 stromer motor bit the dust .The battery is about 6-7 years old and now shows a75% charge.The overheat light comes on after a minute or so every time.I tried the throttle and pedal in the regular mode but nothing happened.It has a torque sensor on the rear wheel also .do not see anything wrong in wiring .disconnected left and right brake separately nothing still.Any ideas please.wondering if the battery due to age is causing problem it tests at 42.5 volts but that does not really tell the whole story thank you in.
