FlatSix911
- USA
- City
- Silicon Valley
I have attached some photos to show the current
I have attached some photos to show the currents chainstay design of the frame. with 5 PSI I have good enough clearance to ride the bike.
I would love the ability to run a higher PSI for the road. I'm a little confused why they chose to have the chainstays bent in.
This does not accommodate fat tires. This clearly looks like it is designed for much skinnier tires.
Way too tight for proper clearance. Remove the rear tire and measure the distance between the chainstays.
At this point you have two choices... Send it back for another frame or run a smaller rear tire with clearance.
I would recommend calling the dealer with the measurement and see what they offer... good luck.
