MollyLorraine
I've got a 2018 Turbo Como 2.0 that I've put about 2k miles on since November. I've gotten stronger since I first got the bike and use the assist less and less. Long story short - I noticed my battery was ticking down even when I wasn’t using the assist.
To make sure I wasn’t underestimating my use of assist, I counted the seconds I used the assist on a recent ride. After a 1½ hour ride and 17.5 miles, I had used the assist on Eco for approximately 2 minutes and 15 seconds when I noticed I had lost the first bar (approx. 20%) of my battery.
I took the bike into my LBS who contacted Specialized and they are going to warranty the bikes computer. I was told it is a “known error” that some '17/'18s Turbos have a bug that mismanages the battery output and the only solution is to replace the computer. I was also told that Specialized doesn’t do much research on riding without the assist.
Has anyone else had this problem?
It’s my goal to go longer and further, working up to a century ride. If I use Eco the entire time I can get about 42 miles (far below what Specialized estimates on their online calculator, but still within expected range, they’ve told me). If not using assist works the way I think it should (i.e. not draining my battery when I’m not using it) I should be able to pull off a century easily. I’ll let you know if the warranty corrects the problem. Fingers crossed!
