I'm sure glad someone has finally asked this question.
I notice you have (or had) a Juggernaut with the Bafang Ultra 1000 and I've been considering a similar one -vs- a rear hub bike like a Juiced RipCurrent S.
I'm considering a generic version of the Jugg (though it has some lesser-spec'd parts - same motor and frame) and had a few questions if you don't mind? I think your responses will be of interest to thread subs also.
First let me state my situation and anticipated riding profile:
A) I'm not a serious rider. I don't do tracks or technical rides. I have a knee that isn't great (I need a throttle). I would use primarily on roads or grassy / dirt trails, rarely any hills involved. I would like to go fast on occasion, I would like to shift gears on occasion.
B) I've ridden a Yamaha mid-drive and loved the fact that I felt like superman, but felt like I was doing the pedaling (even though the bike was doing most of it). Knee was OK with it, but I want / need a throttle.
C) I've ridden a few other hub-drive bikes (one had a cadence + torque sensor, other cadence only) - I felt disconnected from the pedaling. They had ample power to be sure, but as soon as I started pedaling the things just take off. I'm sure I could probably get used to it.
Questions:
1) How much shifting is needed for casual / slower riding? Say if I want to cruise with my wife at around 12mph on level ground, could I leave it in, say, 3rd gear and use throttle from a dead stop, and never have to really shift out of 3rd? I don't want to exert much pressure on my knee, and with a rear hub I can use the throttle to start off (no matter the gear I'm in, and don't have to remember to down shift before stopping) and then start pedaling once the bike is rolling. I do realize the max efficiency will always be achieved by using the gears, and that those nice high speeds will require shifting (no problem, but I don't want to constantly have to do that if I'm casually riding with my wife).
2) When shifting under power (PAS or throttle) does the motor cut / reduce power during the shift (I guess controller would be doing this actually)?
3) Does the controller / display offer good control over max speeds, amp. draws, slow start adj. etc?  I wouldn't want this thing to do a wheelie on my way to the mailbox... I'm a big fan of adjustments and options.
4) I notice your seatpost frame member is a round tube all the way to where it is welded to the motor top-plate. I see some photos of other Juggs that have a widened seat post frame tube where it meets the motor plate (which looks to me like it would be stronger) - I wonder if this was a weak area at some point and the design was changed?
Thanks for your insight!
