Racingkyle
Hello Everyone. Earlier I was not convinced on the M1 Spitzing. Now, after talking to people and doing some research, I've been convinced otherwise. Let me tell you why you should choose this bike over any other bike. First, let's start off with some basic specifications.
-The bike has a top speed around 45 miles per hour
-It can reach 30 miles per hour in 7.5 seconds
-It has an 850watt motor running as a mid-drive
-It has an 880 watt hour lithium LFP battery
-It is a full suspension bike (air suspension)
-It has a full carbon fiber frame
-120 nm of torque
-This bike has a torque sensor.
Now let's move beyond the specs. What makes this bike so unique and special? Well first off, there are 3 different models of this bike you can buy. The pedelec (least powerful), the s pedelec (powerful), the r pedelec (most powerful).
This bike uses a unique drive system in which the gears have around 90% contact. Also, this is an extremely efficient bike. You can get tons of range, so you should have ZERO worries about getting around and running out of power (65-95 miles roughly). Are there any hills in your area, well this bike can handle them easily with 120nm or torque. Torque is the amount of strength a bike has to travel up a hill. The competition is less than 80nm!
This bike uses a torque sensor, so it senses the torque you apply to the pedals and outputs power depending on your settings. You can learn more about this by looking at the picture in the specifications area. This bike uses a custom carbon fiber frame with full suspension. This is going to unlock the ability to ride on the trails. This bike is also extremely light. Only around 58 pounds.
If you have any questions or concerns, feel free to contact me!
-120 nm of torque
