I've seen the R&M Delight ebike with dual batteries connected such that they are both being used simultaneously (i.e. no A-to-B switch) but I am not aware if they have to be the same capacity (i.e. both 400wh or 500wh). Does anyone know if two battery packs of the same voltage but different capacities can be connected in parallel on these or other ebikes? I would assume they would draw down / remain balanced even if not the same capacity).
