Not sure what to look for. Attached a few photos of inner section for you to review.
Thanks again. I will add some washers to my crank to try to center the chainring. Hopefully it doesn't screw up my chainline too much
Although the supermoto x on this bike is nice I was wondering if they are upgradable to a larger size. For example is it possible to fit 700c x 51c tires? I would imagine the fork would have to be changed but what about the rear? something like these would be nice:
https://www.landrys.com/product/specialized-electrak-2.0-armadillo-reflect-307067-1.htm
That’s your chain on the biggest chainring of the rear cassette. It’s normal.
I have a 20 Speed Haibike Trekking and I had to spend around 90 Minutes to get the front derailleur perfectly aligned so that 10 out of 10 speeds would be available on the lower front chainring without ever touching the ‘banana’ of the front derailleur. It just barely fits... LBS said ‘it would never work’ and configured it for 8 out of 10 gears at the first free tune up. They were obviously wrong because the factory setting allowed 10 out of 10 gears without any contact with the front derailleur. So it was just a question of being a hard head and trying until it worked. It’s a setting that requires a good amount of precision.
Urban Plus owners don’t have to deal with this type of problem. So just enjoy the bike.![]()
I only put the derailleur back the way it was factory shipped... and tuned to perfection. There’s a reason it was like that. Nothing contrarian. Just asking that my bike be given back to me the way it was. Nothing more, nothing less. Those 10 gears are now usable, which is what I wanted. I’ve used the bike for a year. 11,000 kilometers. Zero derailleur issues, zero chain issues, still the same cassette. Enjoy your bike.![]()
Nope. Not what the manual says. Use of all gears for "your" bike is not recommended, my bike though only has the 1x10 gear set, so it is like the Immaculate Conception of being perfect. Cheers! Enjoy your seemingly tuned bike, but not so such perfectly tuned but fooling you into believing it is perfectly tuned so that you don't notice... the strain on your chain.Adjustment is one thing, you should be able to enjoy proper adjustment. The use of all 10 gears is contrary to page 55. of the Winora manual. Enjoy your perfectly tuned bike. Cheers!
I have almost 500 miles on the bike now and I wanted to give some impressions. If you're on the fence about this bike, assuming you can still find one, I would endorse it without reservation. I'm 6ft 1" and weigh 267lbs, 43 years old and very out of shape. The entire purpose of this bike was to get me active without getting discouraged, and perhaps commute to work. Getting another car off the road also mattered to me, as well as the potential savings it represented.
I managed to locate the last large UrbanPlus in my city. The company I bought if from is largely know as trend seller of whatever seems to be hot at the moment. As such I had very low expectations of these people understanding what they were selling or their ability to service it. Fortunately I have technical background and spent my years in university as a bike mechanic. I took a quick test ride, negotiated the price a bit, paid and left knowing I'll be handling any issues myself.
After I got home I immediately broke out the tool set and started going over the bike. As expected adjustments and tweeks were needed. Probably 20% of the fasteners weren't tight at all, not even fully seated and showing threads. The front fender top bolt was much too long and bottomed out before tightening up. A stainless steel washer behind the mounting tab solved that. I filled the tires, set up the controls and seat height. I downloaded the app and paired my phone, then took the bike for a blast.
First impressions: It's fast. It has a high quality feel to it. The ride quality is much better than I expected. The brakes are awesome. The handlebar mounted control buttons are cheap and flimsy. The frame geometry fit me well and it handles great. The various power modes worked well. The Cobi app worked very well too. I had planned to do a couple laps around the block and ended up riding 9 miles! Absolutely I was getting exercise and covering meaningful distance while doing it. This thing is meant to commute!
I knew a few accessories were going to be required. I installed a much more comfortable seat from my old bike, a SunTour suspension seat post, a Topeak trunk bag, and suspension stem from RedShift Sports. All accessories have lived up to their claims and made a truly beneficial improvement to the bike. I will need to change the pedals, the supplied pedals are so narrow the outside of my foot hangs off the side. Additionally I bought a tire pump, patch kit, and bike multi-tool. I also carry around a few cable straps, some duct tape, chain lube, and non-bike specific multi-tool.
Riding to work will result in a 22 mile round trip. I wanted to see what I was capable of ahead of time. On a day off I rode to work, and then kept riding, and kept riding, and then much later thought I should head home. I rode almost 30 miles that day, stopping to have a drink of water now and then, and watch the ducks in the canals. I rode the whole time in the highest setting and got home having used only the top half of the battery. I'm impressed.
I've been commuting to work regularly now, not everyday as my legs are still building up to it, but soon I will be. The bike simply eats miles. I've seen 27mph on the speedo, but 19 to 20mph seems to be a good zone where I'm really covering ground and not exhausting myself. I've also found that riding with a higher pedal cadence results in much more efficient performance. I'm still adjusting to this and often find myself trying to torque on the bike rather than let the rpm build the power.
To date the bike has had no failures or issues of any kind. It's thoroughly pleasing to ride to work enjoying the open pathways, logging my performance and fitness improvements, all while listening to my favourite tunes on Spotify. I arrived energised, awake and feeling good. So far the Haibike UrbanPlus has not only been a good buy, but also a good decision.
I don't find that too much of a problem. I think it is getting in the right grove ( pedaling and gearing) and I can obtain it. I can pretty much run a comfortable 24 and 25 but admit 26-28 takes work but then again if you wanted it to be easy then you should have bought a throttle bike.It would seem that the bike in my opinion "likes" the 20 mph speed zone. It takes a lot of work to get to the max assisted speed in relation to the lower speeds. I have the super large style pedals from pedalist and they are great. It takes a little change in the way you ride because the pedal will be lower to the ground when taking corners while pedalling.View attachment 23160
After grinding through every scrap of info I could find I pulled the trigger on an Urban Plus with Amego. I think the value proposition is extremely good - subject to people finding other awesome deals with particular bikes elsewhere, pricing for this brand and quality is really competitive by my survey of what I could find on offer. As for the worries about the TranzX platform, yes, discontinued with Haibike in North America. Accell Group sold a ton of TranzX bikes under the Winora Radar branding in Europe, and my best guess is Bosch led a concerted effort to squeeze them out of Cobi integration and completely out of Haibike if not other brands (including Winora in Europe), because the lower price point was stealing their market share. Look for a Bosch/Cobi offering in one of the Accell brands in North America, (maybe Raleigh?), coming some day soon. I'd also predict or guess we might see TranzX reappear in some of the off-brands - such as Volt, and how long before there is a Kirkland Signature Urban Commuter ebike? To hit their price point a reliable Taiwanese motor might be perfect. Not unlike how the motor scooter market developed in brands like Piaggio filling in underneath Vespa pricing, with lots of Taiwanese components, but supervised by the same manufacturing group as Vespa. The smartphone/ebike integration is an obvious market - including much better security like disturbance push alerts, GPS tracking, who knows what other apps and ideas. So my bet is there will be TranzX and Cobi support for at least several years to come. We shall see. I also think it is the end of the line here for deciding to get one - seems like inventory is shrinking and soon they will be done.
My 2 cents-E-bikes are not really an investment like a rare Lambo or expensive art or even commodities. They are purely for enjoyment and good health and what you get in return from them by far outweighs thinking or getting your money back from it. It pays for itself on so many other levels. Even if you get half of your money back after a couple years is well worth the investment. I just say 'hello fun' and take the high road and go out on a high note. Enjoy!
With you on that too Bob - any consumer purchase I make I don’t really think about resale, except maybe for cars. My assumption today with the pace of battery and electric motor innovation is that technology will render this year’s ebikes obsolete much sooner than this year’s conventional bikes. Maybe there will be retrofit improvements available, but the risk is frame housing sizing for batteries and motors change, in which case, in a few years the value will likely be limited. So be it, I’ll cross that bridge when we get to it. Like you say, I hope to have a lot of enjoyment in the meantime. I’m a big believer that expenses on experiences, even ones with zero financial recovery - travel, special events, fine dining, adventure ... is an investment in a full and interesting life. With material things the usual resolution seems to be a friends and family transaction so I get back maybe a fraction of value or make a gift but I get to see somebody I like enjoy the same thing after my turn is over - and I try and take good care of anything I have so they will get something nice.
