My name is Robb from Portland, Oregon. Where are you located..?
My friend Court ask me to look at your question and reach out to you.
I had some knee pain also, On a recumbent trike, crank arm length is very important to figure in.
I’m just 5’7” tall, (short) and my knee pain was from riding with too long (170mm crank arms). It took some searching to find crank arms that would work with my Bafang mid-drive e-assist. I finally found some 152mm cranks on AliExpress. This solved the problem.
When the arms are too long in the recumbent position, to return stroke brings your knees up too sharply and causes pain. Shorter arms will make the rotation more comfortable. Seat position is very important also. The ICE, AZUB and some of the Catrikes have adjustable seats.
You may want to order a complete trike and try it without electric assist. Some of the lighter trikes like the Catrike 700 and the ICE VTX are extremely light and are designed for speed (it is also narrow to get thru doors) measure the opening in your doors and look at the width of the trikes you are considering. I wouldn’t put electric assist on those because they don’t need it.
MOST IMPORTANT PIECE OF GEAR IS A GOOD HELMET. GOOD LIGHTING AND A GOOD FLAG FOR VISIBILITY. I can send recommendations on lighting, just ask.
I also prefer SPD cleats to keep my feet on the pedals. A pot hole can bounce them off and you don’t want them being drug under the seat at a high speed.
To save some money, I ordered my AZUB without the BB bottom bracket, front derailleur, or front sprockets. I order my BBS02 Bafang 48v 750w mid-drive and lithium ion battery. And installed them once the trike arrived from the dealer.
www.youtube.com/watch?v=akA1vg5fcwY&t=5s
I prefer the mid-drives over the hub motors. I get more torque to climb the steep Portland hills and can utilize my cassette (gears) with the mid-drive. Later, I swapped out the cassette for a Rohloff hub. (it is amazing with a mid-drive system) I think it is really personal preference.
Many places to find Bafang mid-drive kit: Ebay, AliExpress, California-ebike.com or local dealers.
TerraCycle. Pat Franz has many extra parts. T-Cycle.com. has the trike battery mounts that put the heavy lithium batteries under your seat, mounted to the frame. If you get a folding trike, take that into consideration. Some mounting brackets don’t work with folding. TerraCycle has the best Ceramic Idlers and return Idlers on the market today.
For Accessibility. The the assist bars to help with standing up. First lock your brakes and (It is important to place your feet back to the seat, squat down and then scoot back into the seat. To stand up. Lock the brakes again, Place your feed back, scoot to the front edge of the seat, while brakes are locked, hang onto the assist handles and stand up.
http://www.utahtrikes.com/UTCAT-820.html
There are many E-Trikes on the market today.
https://azub.eu/recumbent-bikes-and-trikes/
I own an AZUB Ti-Tris "tadpole" - (2 front one rear wheel) I prefer the tadpoles because they a more stable on corners (but any trike (delta or tadpole) will tip and roll going too fast on turns)
I purchased from Mark Waters from BackCountryRecumbentCycles.com I save a lot of money going thru Mark at BCRC. Then had it shipped to RoseCityRecumbentCycles in Portland where Robert and Jonathan set it up for me.
My trike does not have suspension. And it isn’t good on gravel roads for that reason. If you are going to be on paved road only, you can decide if suspension is right for you. For unpaved roads, I recommend a full suspension FS trike. Azub offers the Ti-FLY FS with wishbone titanium suspension (beautiful and a little pricey.
Azub also offers the TRIcon with rear suspension. This helps even out the road.
Catrike.com. offers several tadpoles.
The Dumont is full suspension. About $4200 . But the front Suspension only has 1/2" of travel. You will bottom out on bumps.
You can get better results with a good set of ballon tires like the Schwalbe Big Apple PLUS E-50 rated or the Schwalbe Big Ben PLUS E-50 rated.
Properly inflated, they will give you more suspension than the Dumont's 1/2" of travel.
Remember, with an etike, it is important to have ebike/etrike rated tires for safety. You will be moving much faster.
The Road is rear suspension with optional front suspension.
ICEtrikes.co offers high end trikes with FS and RS or non at all. About $
A good website to look at all the trikes and the options is UtahTrikes.com. Matt is a friend, he helped me build a Rohloff Hub Wheel for my AZUB. I started out with a SRAM DD3-27 hub. But it has a solid axle and not a QR skewer. I needed a skewer to attach my trailer. And the DD3 wouldn’t accommodate. I also prefer Disk Hydraulic brakes.
I can’t say enough good things about my friend Court. The most important thing is that I trust his advice.
I hope I didn’t overwhelm you with information. If you have questions, don’t hesitate to call.
Have a great day and ride safely my friend.
Robb, PDX. 503-729-1413
