astrogeezer
Have had a German ebike (made in China, surprise, surprise) called NCM Moscow. Great bike until you need to turn sharply or U-turn. The default setting is numbered 1 on the display (not zero for some reason). This setting gives the rider a boost at traffic lights, cross roads etc after braking to a halt. The trouble is, the same boost kicks in while negotiating a tight turn which, naturally, tends to throw you off balance and off the bike. It's happened twice now, and resulted in slight damage to the bike and a swollen knee. I emailed the suppliers, Leon-Cycles in Hannover and asked why the default is 1 and not zero, expecting them to tell me to manually go through the 0-6 display to reach zero before negotiating a sharp turn. Instead, they said to pull the right brake all the time while turning, which is supposed to cut off the sensor. Is that daft or have other ebikes the same problem?
