Reid
So, I added 30ml of automatic transmission fluid into the motor via a brake disc screw hole I drilled through with a small bit held in a pin vise turned by hand.
The squeak is now cured. The motor is working fine.
Anyone else experienced any internal squeak noise from their CCS or other hubmotor?
(I first used oil in a hubmotor in 2009, maybe the first to do so. It can make an unholy mess, but, if properly used, ATF offers benefits.)
