fooferdoggie
Ok I used this in two different tires on our tandem and my commuter asa a tubeless sealant since I had it on hand when I converted the tires to tubeless and wanted a sealant that did not dry out.
I used the flat out in our tandem tires first. The back held air for a month in the last couple of months it lost a little air after sitting several days or a really big temp change. The front once I got the valve stem tight enough would go a week or so without needed air. But the last week or so it has lost air over a day or so.
I had to take the back tire off to get a spoke repaired and I found the tire wet inside with flat out but no real puddle as I expected. I put around 8oz on flat out in the tire. Well I was thinking if the back is dry maybe the front too? So I added some and it has held air since.
On my commuter its been pretty consistent it loosed some air and they need filled once a week. One tire was low when the temp went from 40 to 23 in the morning but other than that pretty constant. Well had a punter on the way home I heard the hiss and after maybe 3 wheel rotations it stoped and the air level seemed ok (I was not sure what tire it was. I was sick for 2 days and did not ride I found the front tire low and added air. Most of the way home it was getting low. Almost made it about a mile from home but it was too low. So hit it with co2 but it would not hold air Could not find the hole to use a dynadart so I walked home (it was raining and the tires were wet) took the wheel off and brought it in the house to see if I cold find the hole after it dried off. Well pumped it off but air is leaking from the bead and there seems no fluid in the tire.
It seems weird I lost 8oz of sealant in a couple of months or maybe 600 or so miles of riding at most on each bike.
Now if. could get 3 or so months of riding between fills it would cost les then most other sealants that dry out. I find if I let the air out of the tire and lift the wheel off the ground I can tap the bottom and feel fluid in there. it seems the fluid needs movement to leak out since the tandem has about 1/2 the miles as my commuter right now and my commuter got the flat out about a month after the tandem. but all the tires lost their sealant.
