I recently tested this Zen model (not the Samurai) in a medium frame for a week. Over the past three years, I have ridden several eBikes (some stolen
... including EBGO, Aventon Level, FUELL, Specialized Vado 3).
I did a round trip to work of about 30KM. There is a 700m elevation - mostly in a single hill. I am a 50y/o in not-so-great shape though I love biking! I live in Toronto, ON (Canada)
I will be testing the Samurai and will provide an update. I summarize the "Zen" as follows:
OVERALL FEEL
This is the BEST 'feeling' bike I have EVER ridden - better than the FUELL. I felt like I was on a motorcycle. I was able to weave in and out of traffic, zip from bike lanes to sidewalks to park trails. It was incredibly comfortable and surprisingly maneuverable. Given its weight - I was worried it would not feel as nimble as a traditional bike (non-electrified)
FRAME/COMFORT
The bike has a similar frame to the Samurai. I am about 5'6". It was comfortable with the seat at its lowest setting. I was able to get on and off the bike with relative ease though the Samurai model seems to have a slightly lower bar which would make it slightly easier. I would prefer a mid-rise. The frame is solidly built. It felt very solid without any vibration or bending.
MOTOR/CONTROLLER
The bike is powered by an Ananda motor. I believe its 500W. It was quiet with nominal noise at low speeds while at high speeds I did not notice any sound. It is very powerful. There are 5 power levels. The big seems to go from modest to very high. I did not notice any discernable different on the last 5 levels. It seems like from the 3 level onwards - it is at full power. It would benefit from spreading the power levels more evenly. Ravi advised that it will be modified as suggested.
Ideally it would be great to have the ability to customize your power levels such is done with Specialized bikes or some other companies.
Another minor issue is the cables coming out of the motor (or through the assembly) to the rear wheel is exposed. I suggested this being covered or 'caulked' to eliminate water getting in. Ravi agreed.
ENVIOLO "Transmission" (not a derailleur)
It is smooth and quiet. Though I was told to slow slightly before shifting - experts at various LBS' said you do NOT need to. (I did slow my pedaling before shifting). I did feel that it needs a lower gear. Perhaps because the motor is so strong - there was no resistance while pedaling when motor is at the 3rd level (or higher). I rarely shifted from the flat position - even when going up a steep hill I must travel to get to work.
I would be happy with any IHG. With this bike (or most riding I do) - I really only need 3 gears - flat, steep and one in the middle.
HANDLBARS
LOVE the handlebars. They are adjustable (with a tool). They are very comfortable.
RACK
The rack is nice but I would prefer if it was 2cm longer as my pannier is on the larger size. Given that many people who use this bike will likely go on long journeys - this is likely useful.
DISPLAY
The display is basic. It shows the power level, speed, KM ridden and battery level (5 'buttons'). It would benefit from at least a few modifications including % battery so that one does not go from 20% to 0.
The FUELL display would be the Gold Standard with many features and ways to adjust. However, I used few of those features. Accordingly, I was happy with the information provided - aside from batter level.
WEIGHT
The bike is on the heavy side which is the result of having a large battery. If you were living in an apartment - this could be a problem.
BRAKES
The brakes are good. The bike is able to stop in short order.
SEAT/FRONT SUSPENSION
The front shock is excellent. It dampens bumps well - and progressively. I was very impressed by it.
The seat was comfortable.
The suspension was a little stiff. I would prefer it to be a little softer to absorb bumps a little more.
TIRES
The tires are great. The size is great for riding in multiple conditions.
BATTERY
The battery is BIG. I rode about 65km before charging with the battery indicator on the 3rd bar (not sure actual percent available). While in theory each bar represents 20% of the battery life - I find that on most bikes the relationship is not linear.
OVERALL
Great Bike
Great Value
VERY powerful motor
very quiet bike
Very solidly built
FEATURES TO ADD
As I discussed with Ravi - I would love to see a way for anti-theft features to be added such as brakes that lock or a way to lock the pedal or motor on demand.
I am looking forward to comparing this to the Samuari.
I will update pics soon
Michael
