Those $80 no name brand china made hydraulic brakes will be as crappy as the rest of the radmini folding bike for $1700. Real shimano good hydraulic brakes with cut-off add a
minimum of $200 installed. Also even though both bikes are considered "portable", the haibike weights only 49lb while the
radmini is almost 20lb heavier or 40% more at 67lb, it leaves out the fact that the radmini breaks the frame and adds a hinge, while the Sduro Radius does not and makes the sduro the stronger stiffer more responsive better lighter ebike, yet still portable with a swiveling handle bars, telescoping steering tube, and flip-folding pedals that allows it to become very flat.
As far as range, from Court's own words:
Sduro Radius Min range: 53mi, Max range: 128mi, Radmini min range: 22mi, max range: 42mi or 60% less on average
https://electricbikereview.com/haibike/radius-tour/
https://electricbikereview.com/rad-power-bikes/radmini/
So what good is a 36V 500W vs 48V 670W battery when the 36V500W battery produces 60% better range and speed (with BluePed tuning I get 28mph) with similar torque (70 vs 80 Newton meters). And since I both test rode a RadMini and have a Haibike Radius, I can tell you for a fact that the Radius
OBLITERATES the radmini in range, quietness, speed, frame strength, stopping power, responsiveness and portability, not to mention that the feel of a mid drive bike is eons ahead of anything that a rear hub motor bike produces. And does it for $500 cheaper for the price that I paid with local warranty and service.
Those range estimates are meaningless. Those figures are estimates from the manufacturers themselves and I have no doubt the haibike figure is massively inflated. No one in their right mind believes 500 watt hours delivers BETTER range than 672 watthours. This is pure delusion.
You say that the haibike "obliterates" the rad in range based upon a test ride?!? How long were your test rides? You test rode your haibike for 128 miles?!? I bet the bike shop sent out an APB in that case! Your rad test ride was for 42 miles? You just said those were range ESTIMATES. You have no clue what the actual range is.
Stopping power: do you realize hydraulics only advantage is in wet weather? Even rim brakes will stop as quickly as hydraulics when it's dry. Did you test the brakes in a swimming pool? Torrential downpour? Except in wet weather, hydraulics do not stop the bike faster.
The haibike is faster? Hub motors are faster on pavement; mid drives offer more torque but accelerate more slowly. Both top out at 20 mph.
The review you linked to lists the haibike as a class1, not class3. 20 mph top speed.
Frame strength: you have no evidence that the haibike frame is any "stronger." How many load cycles is each frame capable of? Which lab did the testing? Show your proof.
Quietness: did you use a decibel meter or app? What your figures for both bikes? Show your data.
I watched both review videos and there doesn't seem to be a significant advantage for the haibike in terms of motor noise. There is a lot of wind and tire noise in the radfolder video, so hard to tell. Not to mention,
the yamaha cuts out at 100 rpm, which would account for it's relative silence: it's not working! Easy for a motor to be silent if it's not even on eh?
A folder isn't necessarily any less stiff than a standard bicycle. Tom Ritchey's folder is renowned for it's stiffness even though it has multiple hinges. Take a look again at the ridiculously low standover (not a bad thing) on your haibike.
To compensate, the seatpost is extremely long. This will introduce flex. Look at the
specialized roubaix 2017-. The seatpost clamp was lowered deliberately in order to introduce flex. This design is an intentional feature. Flex is not bad. Flex, in the right amount, is a beneficial feature. Now look at the radfolder. A normal standover. That means less seatpost is exposed. This means less flex. is that good or bad? Depends upon what the rider wants. Are you extremely heavy? You want less frame flex. Lightweight? you want more. Eliminate flex completely and a frame becomes wooden, unresponsive not to mention unnecessarily stiff and uncomfortable. You are ignoring basic principles of frame design. Not to mention you don't have any idea how much flex there is in the haibike vs rad frame in the first place. It is possible to measure frame stiffness. You don't have any data, yet you make absolute claims without the slightest justification.
You are being sneaky and saying the radfolder is unreliable. I could say the same about the folding pedals or telescoping steerer are flexy on your haibike and could collapse and fail at any moment. Look out! I have no evidence to back these claims so I don't make them. Of course, evidence is completely irrelevant in your assessments, so go ahead, say whatever you want, just because.
Weight: you say the rad is 67 lbs. It is 63.7 lbs. It does weigh more, but at least get your facts straight.
Local warranty and support: lucky you. Rad riders can get that same support depending upon their location. So can haibike riders. Depending upon location. Since you were able to test ride the rad, that means you would have had local support for the rad as well, had you so chosen.
Feel: you say the yamaha is "eons" ahead. What unit of measure is an "eon?" That is a measure of time, not of "feel." Not to mention you don't define what "feel" is.
As noted, here is a full set of ebike compatible shimano hydraulic brakes with brake cutoff for $112.
https://www.amazon.com/SHIMANO-Hydraulic-Brake-Bafang-Shi-ma-no/dp/B06XCMP6NQ
In reality, you have absolutely zero evidence to support any of your claims. You have hyperbole (hype) but not one iota of evidence of support for any of your claims.
