Hasaf
In a different thread, there was a bit of a consensus that a direct drive rear hub was best for commuting. However, there was little discussion of why that is so.
I have a mid-drive motor on my DIY commuter, driving a NuVinci N380. I happen to think that IGH transmissions are best for commuting. That nearly precludes a rear direct drive. Yes, I know there is an exception, a direct-drive with a five-speed IGH. I have one here in my office, it was DOA and the support from the Canadian vendor was a form of, "you buy, now go away."
Ignoring that exception, most direct-drive rear motors call for a standard exposed gear arrangement, which I don't consider ideal. In addition, the motor can not use the gearing. My TDSZ2 definitely calls for use of the gearing when starting and riding against strong winds.
In comparison with a geared motor, the direct-drive has more drag when out of use, and is significantly heavier. My first commuter, yes also DIY, used a geared front hub, as I didn't want to remove the IGH and belt drive. It was actually well balanced and hen riding to work in snow and ice (yes, studded tyres) it had a bit of a two-wheel-drive effect that worked well.
So, no IGH, and no running the motor through the gears, and heavier than the geared drive,why is the direct drive considered a better choice, I just don't see it
