I was moreso referring to the number system rather than the X/S Duro nomenclature. I understood the number system to refer to the quality of the components (similar to Trek's system). So to go from the 4.0 Trekking to the 9.5 or 9.0 I expected a big jump in components. But they look largely the same which leads me to believe they have reset the number system in addition to changing the XDuro, SDuro nomenclature. I must say that on my 4.0 Trekking, the gear shifting is really smooth and the brakes are phenomenal. For what that bike is designed to be, it seems to be spec'd rather well as-is.Yes I know they dropped the xduro and sduro names relating to the motor type. Haibike has some of the worst model nomenclature out there if you ask me! None of the companies do a particularly good job of it though.
anyone else think these are under powered at all at 350W? Especially for the price?
No.anyone else think these are under powered at all at 350W? Especially for the price?
You ever rode one? I have two, they are definitely not underpowered! I have 1300 miles on one, 1600 miles on the other, both are 2016s.. The full suspension bike will actually pull the air fork back when riding in the turbo mode. Any more power and the back tire will be spinning. I don't buy the new model year, so I don't pay list. But these things are an absolute joy to ride!
You also need to learn about any laws regarding speed and wattage restrictions in your local area if you intend to utilize bike paths. For example, here in Georgia, bike paths are restricted to 20 mph assist and 1000 watt motors, which is higher wattage than the federal limit of 750 watts. It’s really a hodgepodge out here; we really need a national set of rules.I haven’t actually! I don’t really have anywhere near me to test ride one, I’m new and just learning about this stuff. Im a pretty heavy guy (230lbs) and i just want to do about 15-20miles one way on torque sense mode for my commute. I thought with my weight I would need a higher wattage but you’re right i should test drive one. It’s just concerning when I see other bikes with 750-1000 w motors with 48v batteries and it all seems like quite a jump from just 350w 32V!
There seems to be an error on Haibike's website. The new Trekking Xduro S 9.0 is depicted with the same frame as for 2017 (shown in the picture below). But the spec sheet mentions an IBC (Intube Battery Concept) frame coupled with a traditional Power Pack. So something doesn't quite add up. If you have an intube frame, it would make sense to ship with an intube battery. Either the image is wrong or the spec sheet is wrong. Unfortunately, I suspect the image is correct and the stated specs are wrong.
Link: https://www.haibike.com
The picture on the website:
The accompanying description:
However, an Intube frame should look like this:
Edit: Checked it. The spec sheet is wrong on Haibike's website. The 2018 Trekking S-Pedelec model is basically the same as the 2017 model (meaning no Intube battery). The 2018 model is shown at 2:37 in this video:
Although the powertube is more aesthetic, the 2018 trek with classic battery is not far behind. I still prefer the later since a spare battery would easily fit in a back pack or big saddle bag (easier to carry a spare).
