Sergey Kirienko
hey everyone. im pretty new in those forums,
but im using electrical scoolter for more than 7 years now.
im pretty happy with it, its powerfull and stable.
before i explain you guys my problem, i need to put some details into it:
- i have 500w brushless motor, 12.5"
- lithium battery (48v, ~15A) 6 years now, didnt replaced yet.
- controller i did replaced because some water went though.
recently i had this problem when i throttle to the maximum, the scooter starts to gain speed and in some point the whole thing just stops working and the battery indicator shows from 100% down to 0%
when i measure the battery voltage i get 0.5v unless i wait about ~20 minuts or disconnect the battery completly from the controller, then when i connect it right away, it indicates 55.4v battery and then everything works like normal like nothing happened.
first i thought there is a problem with the controller, so i replaced it. but the problem didnt dissapear.
so basically; when i run my scooter without any throttle, everything works fine, but when it comes to higher throttle points, the whole system disconnects.
i was thinking it can be problem with battery, or maybe wires, or is this some common problem that needs replacing the battery protection?
i would like to hear some information about this if that happened to someone else before, please tell me. and the way you fixed it.
