pushkar
OK, I believe we are ready to take the next steps on the quiet gears project.
How will this go? What are the timelines?
You will get a unique set of gears - either PEEK or Custom Metal. Both will be quiet - (higher tolerance)
Disclaimers
- We are working on a production timeline 3-6 month timeline starting May 1st.
- First set of gears will be delivered in 75 days from May 1st.
- Testing for the rest of the time and providing feedback.
- Our assumption is that Metal and PEEK will be very similar in terms of noise if built right.
- We will provide the picture of the gears or identify what areas are being switched - so you can decide.
- Cost of gear sets (we will provide 3 gears) is $450 + shipping from Asia
- Using PEEK will limit the overall wattage you can push through the motor. We believe it can take only up to 1500W.
- Using Higher tolerance metal gears will actually allow you to push more wattage through the motor
- "Choose wisely, You must" - Yoda
- Cost of quieter motor enclosure (this will replace the current case / shell) - $500 + shipping from Asia
- Used in conjunction with Metal gears, this will probably be the best setup for long term usage.
- Used in conjunction with PEEK will make this super quiet - but wattage will be limited to 1400-1500W. Throttle will be limited to 750W.
- 5-10 riders who own a Bafang ultra, (and ideally the Archon X1 controller), who would want to put the gears in their motors, or would want to put the current gears in the new enclosure, and provide us feedback
- Feedback needs to incorporate sound measurements (check out some DB meters from amazon) on gears, motor whine and change in overall motor noise, "feel" for when the gears engage (probably quicker).
- Qualitative feedback on ride quality, motor response under different riding conditions (flats, inclines, singletrack, weather etc).
- Posting feedback on public forum is ok.
- Please read the disclaimers before "volunteering as tributes "
Disclaimers
- This will void your existing motor warranty.
- There will be noticeable noise reduction, but we wont be able to defy physics.
- Timelines are provided by manufacturer - but with everything going on, we may epect some slippage.
- This is a financial commitment and carries risk - Not all gear styles will work and there may be failures.
- We will try to build the strongest we can but we cannot warranty the gears.
