Sirrus X 5.0 is a 10 kg/22 lbs bike...Actually, the warranty most likely would cover that. I have a carbon Sirrus X5 with a kickstand that has tipped over once and suffered no damage.
It is still a little hope Specialized would re-think the matter and produce a Vado SL 1.5 E5 with a more sleek alloy frame and the 320 Wh battery... Although I don't believe it myself as such an e-bike would cannibalize the SL 2 Carbon sales.This is the bike I've been waiting for, updated Vado w/ SL 1.2 motor.
Ain't no way in hell I'm buying, though. It's become a pig.
SL 2 Carbon has a bigger downtube, specifically made for the new 520 Wh battery...Specialized could offer a custom, special order 320 Wh battery option across the entire Vado 2 range, a genuine SL for the luddites
Full size Vado is 58 lbs (with battery?) 45 lbs is already super heavy and unwieldy for stairs given the awkward form factor of a bike.Then when you get to 45lbs+, wouldn't it be better to get a full power ebike withmore power, bigger battery, and just use a low power mode?
IMO the carbon fiber amplifies the noise of the 1.2 motor. I think it’s louder/more present in a carbon bike than a 1.1 in the aluminum bikes.I loved my betamax...it was always better than my later VHS lol.
I've said it before..if I had one complaint..it would be motor noise from my 1.1 motor. It isn't a deal breaker type problem....it's just me being nit-picky.
I'll leave it to the overlords at Spesh who decided to make a bike with "super light" in its name title into a 'sort of light-ish but nearly heavy' ebike at its latest iteration.
Seems to me that the engineering department forgot to run this one by the sales/marketing people.
You should decidedly give the motor a tryI like riding my Vado 5 SL without motor assist so much that I haven't been tempted to use the motor!
Yes, I think so. At least my Vado 6.0 weighs the same.Full size Vado is 58 lbs (with battery?)
Double checked, it is the LTD that weighs the same as our current bikes at $8000, the $6000 SL 6.0 weighs almost 2.5lb more at $6000 than my 5.0.This is the bike I've been waiting for, updated Vado w/ SL 1.2 motor.
I'll continue riding my steel Dr. Dew and regular Vado. O well.
You should have bought a Sirrus X 4.0 at less than half the price and 10lbs lighter than the non eq SL 5.0.I wonder how the Vado 2 SL rides without motor assist?
Oh that is interesting. Now that I ride with my Shokz bone conduction headphones....motor noise is not much of an issue for me....even if motor noise does remain.IMO the carbon fiber amplifies the noise of the 1.2 motor. I think it’s louder/more present in a carbon bike than a 1.1 in the aluminum bikes.
Problem is with added power comes faster battery drain.It will be interesting to see what or if they do for an aluminum version of the Vado SL 2. In the meantime, the Creo SL 2 E5 is will be very easy to convert to a flat bar because of the SRAM components. Bars, brake levers, shifter and a control switch. A few more parts to add the wired lights.
Only if you actually use the added power. And if the SL 6.0 still weighed what the 5.0 does, you might not.Problem is with added power comes faster battery drain.
My current gearing for Vado SL 1st Gen is Shimano 11-51T M5100 cassette and derailleur (11 speed). The 46T chainring could be technically installed there (I use a 42T).The 10-51T rear cluster with my current 46T Wolf Tooth chainring would be just the right gearing for me. I like the idea of carrying 820Wh of combined battery for extended range.
Then I see no benefit.Only if you actually use the added power. And if the SL 6.0 still weighed what the 5.0 does, you might not.
