Vado 3.0 - What Tire Pressuure Are You Running?
lewes5
Curious to know what tire pressure range are you running on your original Vado 3.tires? I know that pressure is somewhat dependent on extreme rider weight, high or low.
How often must you top off the air to maintain your preferred pressure range?
(Or is the tire pressure question similar to the proverbial oil change frequency question found on most automobile fora?) :rolleyes:
I used to inflate my Trigger Sport 700/47mm to 4.2 - 4.3 bar.That would be the same as 61-63psi.
Right in the middle of the 50 - 75 psi as is recommended for that tire.
I weigh 155lb.
Checking pressure after 3 or 4 day and usually had to add 2-3psi.
