Turbo S thumb control
carlo
Hi,
I bought a specialized turbo S in 2013 with red thumb control, now it appears that this button control is broken. In Europe this part is no longer available so I can only ride my bike on max support, so no more eco, no load or no support choices. It is hard to believe that after 6 years no parts will be available. I don't know if you can help me.
Regards.
carlo
If you can get a new battery that supports Bluetooth, you could control it through the Mission Control app.
Hello,
sorry for my late reply, thank you for responding.
I have a friend who has this bluetooth battery, we have overbuild the battery in my bike but it diddend work,
we have than overbuild the red thumb button and it worked.
Now I know for sure that the thumb button must be replaced ....but .... this part is no longer available in europ.
Can you help me further?
Kind regards
Carlo
Someone I know had a Turbo S with the Bluetooth battery but without the thumb button. Maybe he never ran it on any level other than Turbo. I'll try some tests on mine.
I tested mine by disconnecting the control/display. The Bluetooth connected no problem, but the app doesn't give you a way to select Eco mode. Only smart control.
[QUOTE = "ROJA, post: 236492, lid: 8516"]
Misschien contact opnemen met een grotere gespecialiseerde winkel in de VS - ze waren op voorraad vanaf vorig jaar toen ik de mijne liet vervangen.
[/CITAAT]
Hallo
Kan je soms de dealer die je geholpen heeft, het adres daarvan doorgeven, dan kan ik daar navragen.
Dank u.
Groeten
carlo
