So with the torque sensor can you leave it in level five and it will regulate the speed (depending on the amount of torque you apply to the pedals) from 0 mph to max?I have both. Torque sensor is the only way to go. TS makes more of a natural peddle cycle. Cadense goes to the level of power you have chosen as soon as you start to turn the pedal. Example: One of my bikes is a Cadence Sensor bike. If I choose level 5 assist and pedal very slowly the bike will do 24mph.
well sort of it will give you assist so it makes peddling easier. the harder you peddle the more the motor helps. of course that means going faster but it really means going faster with less effort.So with the torque sensor can you leave it in level five and it will regulate the speed (depending on the amount of torque you apply to the pedals) from 0 mph to max?
So why the need for different levels of assist?well sort of it will give you assist so it makes peddling easier. the harder you peddle the more the motor helps. of course that means going faster but it really means going faster with less effort.
Yes. With mid-drive motor/torque sensor, you can pedal very lightly and slowly in the highest PAS and you can still ride slowly. I experienced that on my last Monday ride in a city where I had good reasons to ride almost in standstill (for example, while approaching signals to wait for them to turn green), was in Turbo mode, and had to concentrate my whole attention on the traffic around; no time to reduce the PAS level. My other hub-drive motor e-bike with cadence sensing simply doesn't let me ride slowly.So with the torque sensor can you leave it in level five and it will regulate the speed (depending on the amount of torque you apply to the pedals) from 0 mph to max?
For instance, when you need to ride up a serious ascent you need more power/torque from the motor. Or, you need to accelerate very very quickly. Or, you want to maintain high speed at relatively low cadence. Given assist level for mid-motor multiplies your leg power/torque and the motor responds with assistance. For example, my Vado set to 50% assist amplifies my legs with 160% ("it's 1.6 x you!"). If I want more assistance, I use 100% support "it's 3.2 x you!" If I need more workout, I use lower assist levels (some e-bikes such as Specialized or Giant ones let you tune the assist levels).So why the need for different levels of assist?
Not really.So with the torque sensor can you leave it in level five and it will regulate the speed (depending on the amount of torque you apply to the pedals) from 0 mph to max?
The PAS level controls amount of current going to the motor. Maybe some people never adjust it, but I lower it as I don't want maximum power all the time. It dramatically shortens battery range when you ride in turbo. But I do leave it in turbo on intermediate single trails when I'm climbing and shooting over rocks and roots. Besides with that kind of riding, I'm all done for after 10 miles and have plenty of range left. In a Bosch, the assist levels max out at this percentage of assistSo why the need for different levels of assist?
The PAS level sets a baseline. And you pedal above that baseline. You still get all the exercise but reach your destination faster.So why the need for different levels of assist?
its how much you want to work. like on turbo I can peddle and hardly get my heart rate about 90 and do 20mph. the lower the level the more I have to work to keep that speed. all the levels will get me to the max 28mph its just how much I want to put into it. my computer shows me how much work I do verses the motor. on turbo I may only be doing 20% of the work at the lowest level eco I would be doing about 60%So why the need for different levels of assist?
Bosch, Brose, Yamaha, and Shimano Systems also have sensors to measure vehicle speed and pedal cadence. They use these sensors along with the torque sensor to provide the appropriate amount of assist for a given vehicle speed. Vehicle speed is directly proportion to pedal cadence. Vehicle speed is not determined by the assist level setting (eco, trail, and boost for Shimano). Only the rider‘s pedal cadence determines the bike’s speed. The assist setting only controls the amount the motor assists.I am not aware of any torque sensor bikes that try to equate user power to speed(assuming your below the speed restriction). Perhaps Stefans bike works differently
wife and I go light mountain bike riding on our tandem with a bosch motor its great. I can shift assist levels instead of gears as the terrain changes.I've ridden bikes with torque sensing and the engagement is sureal. If I was a mountain biker or serous road biker, I'd want a mid-drive with a torque sensor. But for my day-to-day commuting around town a cadence sensor is fine.
Why this? Did someone post something that upset you and/or was incorrect?Not another one of these threads.
Set it to the highest assist level and select the appropriate gear for your preferred pedal cadence and bike speed.Ok thanks I'm getting the picture. Now I do mountain bike in addition to ebiking so say I'm emtb and I'm looking to save my knees for when a mtb ride, what's the technique for expending very little energy but getting the optimal speeds required for a fast run with the torque sensor type?
