Is there a way with the X1 controller to have the throttle come back on after a brake even or shift sensor event?
For example, if I hold the throttle at 25% and either tap the brake or shift the throttle will shut off which is good but it will not come back on unless I release the throttle, wait a second then reengage the throttle.
I didn't see anything in the programming to modify this.
