I am seriously looking into the CrossCurrent and the CrossCurrent Air by Juiced but open to any other suggestions. The thing that attracts me to those are the apparently good torque sensor for the price range and the battery integrated into the frame.
I got my crosscurrent air WednesdayI am seriously looking into the CrossCurrent and the CrossCurrent Air by Juiced but open to any other suggestions. The thing that attracts me to those are the apparently good torque sensor for the price range and the battery integrated into the frame.
Cool! I would love to hear your thoughts after you have a chance to try it out. Did you upgrade to the torque sensor?I got my crosscurrent air Wednesday
The funny thing is im not sure what kind of sensor I got because I ordered a standard version and got a throttle with mine and it says torque sensor on one of the bars on my bikeCool! I would love to hear your thoughts after you have a chance to try it out. Did you upgrade to the torque sensor?
They all include throttle now for no extra charge. If it has the torque sensor you will definitely notice the motor kick in when pedal pressure is applied.The funny thing is im not sure what kind of sensor I got because I ordered a standard version and got a throttle with mine and it says torque sensor on one of the bars on my bike
Thanks so much for this review! It sounds like I am in almost exactly the same situation as you with a 4 mile commute to work (though a few more hills) and I am exactly the same height and weight as you so it's good to hear that this bike works well for that. I assume you got the larger frame? I was lucky enough to order mine after they started including the throttle but unlucky enough to miss the first batch so now I have to wait until mid August when they get their next batch in. I probably could have gotten it sooner if I had ordered directly from the company but I ordered through a local bike shop because my city offers a $200 rebate which minus tax is enough to buy a few more accessories or a decent lock. This waiting period has given me more time to shop around and look at other bikes but I still have not found another bike in the same price range that gives you as much as this bike seems to. The second best options all seem to have cheap cadence sensors for pedal assist.I have the CrossCurrent Air, and so far I’m very happy with it.
I paid the extra $199 for the torque sensor, and another $99 for the throttle. Bad move on the throttle, since they decided to offer it for free only three weeks after I paid $99 for it Oh well, Juiced Bikes also upgraded the standard battery from 7.8AH to 8.8AH at no extra charge, so there’s that.
Anyway, like I said, I’m very happy with the purchase. I bought this bike for a four mile (each way) commute to work, and for that purpose it works beautifully. I typically ride it in “Overboost” or “Sport” mode all the time, as that setting provides the type of power I’m usually looking for. In all honesty, when you lower it back to levels 1 – 4, the bike almost feels like it’s “dragging”. It isn’t dragging of course…it just feels like it when you get used to riding in Sport mode all the time.
The bike has plenty of power. In Sport mode it really does launch you up to 25+mph pretty fast. I’m 6’0 and 175lbs, and I do get to about 25mph before I have to start working harder to maintain speed. Otherwise, holding steady at 25mph is a breeze. You still have to exert some effort, but not enough to break a sweat. I opted for the torque sensor and am glad I did. IMO, riding an electric bike with a torque sensor makes it feel more like riding a “real” bike. It’s kind of hard to explain, but if you’ve ever ridden both cadence sensor bikes and torque sensor bikes you’ll understand what I mean.
The bike will climb small-to-mid-size hills and inclines perfectly fine. It’s all a matter of properly using your gears. But as with most bikes that use a standard hub motor, you won’t get much help climbing the steepest of hills. Then again, if a person will regularly need to climb steep hills, I’d advise that person to buy a bike with a mid-drive motor anyway. Gotta use the right tool for the right job. My commute is mostly flat road, with just a few small inclines. The CrossCurrent Air handles those inclines with no problems at all.
While I realize that an 8.8AH battery won’t provide enough juice for some people, for me and my short commute it’s perfectly fine. When I get to work I still have what feels like full power. I did do one ride of about 15 miles, where I was in Sport mode the entire way. I pretty much used every bit of available battery on that trip. So, if a person will regularly need to ride that distance and they want to be in Sport mode, that person should consider a larger battery (unless they can charge the battery in-between trips). I’m noticing that with a fast electric bike, it’s very easy to ride 15 miles without even realizing you’ve ridden that far. So yeah…I can totally understand why many people opt for a larger battery pack. I suspect that when it comes time to replace this battery, I’ll probably opt for a larger pack myself. But for now the 8.8AH battery I have is perfectly fine, as it gets the job done.
In all other regards the bike appears to be of high quality. No problems so far. I had my bike assembled and tuned at a bike shop because this was my first modern electric bike, and I didn’t want to mess around with it (or mess it up) myself. Turns out this was a good idea, because the bike shop said that the handlebar ring included with the bike didn’t fit. (Sorry, I forget what this part is called…it’s the little plastic ring that you put on the stem before installing the handlebars.) The shop put on a different ring at no charge. They also adjusted the brakes properly and made sure everything was as it should be. If you’re at all mechanically inclined, the bike is very easy to set-up yourself. But I’m sort of an idiot when it comes to anything mechanical, so I was happy to have the bike shop put it together and give it the once over.
Oh, I did buy a Thudbuster suspension seat post in an effort to better support my rear end. I’m a thin guy, and my rear end has absolutely NO fat cushioning on it. I bought the ST (short travel) Thudbuster rather than the LT (long travel), and unfortunately now wish I had bought the LT model instead. With the #5 elastomer in it, the ST Thudbuster model really doesn’t provide much extra cushioning in my opinion. In fact, I barely notice any difference at all. I hadn’t purchased the LT model because I was afraid it would sit too high on the bike. Turns out that wouldn’t have been a problem, and from everything I read the LT model provides much more actual suspension than the ST model. Oh well…live and learn.
Overall I’m glad I bought this bike, and I would have no reservations recommending it to others. I only have about 150 miles on it so far, so it’s still very much a new bike. But so far so good! Juiced Bikes does a fantastic job of offering a quality product at a low price (compared to the competition). I’m already salivating over some of the new bikes Juiced has in its pipeline. In another year or two I might have to buy another bike from Juiced!
Thanks for the info! It has been SO hard waiting for my bike and I still have a month to go! I can't wait to ride it. I'm hoping the stock battery is sufficient for my 4 mile mildly hilly commute to work and small trips around town with a baby seat attached on the weekends.Hi, the top tube on the large frame is 55 mm from the seat tube to head tube. Seat tube 48 mm. Had my CC Air about 2 weeks now. I I'm 6 feet 1 inch tall and the large frame is good for me. In answer to your question about riding without power. Yes you can, although my 11.6 ah, 48v battery is heavy. I have ridden a bike with a 36v 8.8 ah battery, with the power off, and it was easier to ride. But of course with a bigger battery you don't need to worry so much about running out of power.
Yes, I know how you feel. I placed the order for my bike on May 15, and received it June 30. Although I'm a very disappointed today. As I was on my way home, for no apparent reason, a spoke broke on the rear wheel. Such a nuisance as I really needed the bike for commuting this week. I contacted Juiced and spokes are not covered by the warranty. I have ordered some spokes from the juiced website as these spokes are a particular length that by local bike shop does not have. The broken spoke could have been caused by incorrect spoke tension, or it may be the wheel needs truing. So ill get my bike shop to fix the broken spoke and then hopefully i'll be good to go.Thanks for the info! It has been SO hard waiting for my bike and I still have a month to go! I can't wait to ride it. I'm hoping the stock battery is sufficient for my 4 mile mildly hilly commute to work and small trips around town with a baby seat attached on the weekends.
Oh yeah, I guess I never thought of specialized parts that could break. In that case it's better to buy from a US company for ease of getting replacement parts.Yes, I know how you feel. I placed the order for my bike on May 15, and received it June 30. Although I'm a very disappointed today. As I was on my way home, for no apparent reason, a spoke broke on the rear wheel. Such a nuisance as I really needed the bike for commuting this week. I contacted Juiced and spokes are not covered by the warranty. I have ordered some spokes from the juiced website as these spokes are a particular length that by local bike shop does not have. The broken spoke could have been caused by incorrect spoke tension, or it may be the wheel needs truing. So ill get my bike shop to fix the broken spoke and then hopefully i'll be good to go.
So my advice is to take your new bike to your local bike shop and get them to check the tension on the spokes. Make sure the wheels are trued, as well as adjusting brakes and gears.
Was it the Evo Cross? I see this one on their website and it looks pretty awesome. One potential issue is that if I wanted to upgrade to a longer range battery it looks like their battery is built into the frame so not sure if it is upgradable?Bought a new 2016 closeout Easy Motion Evo 2 wheel drive 48v ebike for less than that with shipping. Awesome bike, great power, torque sensor, integrated frame battery (10.5aH), 2 year warranty on battery and 5-year bike warranty from BH.
Mine is the Evo Snow which is 2 wheel drive (motors on both wheels) and wider tires but very similar in design to the cross. The battery is removable and replaceable but not sure if they sell a larger battery or not for it. I suppose you could buy a 2nd second battery to swap out. That Evo Cross deal they have is an awesome price. I like these bikes because they are stealthy.Was it the Evo Cross? I see this one on their website and it looks pretty awesome. One potential issue is that if I wanted to upgrade to a longer range battery it looks like their battery is built into the frame so not sure if it is upgradable?
Yes, it looks like your Air will have more power than mine. It also comes with a rear mounted kickstand, as opposed to center mount which mine has. That means the peddle doesn't collide with the kickstand when you move the bike backwards. I can't complain i did get a free throttle, that was an upgrade when I ordered. Anyway, my bike is still off the road at the moment. Ordered a pack of spokes from Juiced on Monday and received them this afternoon. Tomorrow i'm taking the bike down to Sun Cycling (listed on Juiced website as a dealer) to get the spoke fixed and i'll ask them to true the wheels, adjust the tension of the spokes. I understand they do wheel re-builds, so if the spoke breaking turns out to be an ongoing issue ill get them to build me a better wheel. Although hopefully that wont be necessary.OMG, looks like the new batch of Airs arriving mid August have been upgraded to 500w motor and 9 transistor controller for 30% more power!
