MinnBobber
Hi,
for a carbon fork with it's "mystery to me" compression fitting in the head, should there be any play in fork bearings?
At rest with front brake on, should there be any movement forward when pushed? No movement or is small movement allowed?
What does it take to adjust the play out properly, without crushing the carbon forks?
Doable by novice or you do need a pro for this???
What would you call that "repair/adjustment"?? If I wanted to search youtube and try to learn
a little more about this mystery zone
Thanks for any help.
