Speed sensor PROBLEM!!! no light no work-y
andre starr
i have bbs002 (500w) all the sudden the speed sensor will not work
i bought a brand new one and it still doesn't
the light on it does not illuminate either
seems like a wire issue ? any way to replace it?
from (inside )motor? could be just the connector?
worked great for over 3 years now i'm kinda frustrated at this...
You can try cleaning the connector with some Contact Cleaner
If that doesn't work you could cut the connectors off and solder the wires. Then wrap it with some water proof heat shrink tube
